Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Shark Flex DuoClean LED Headlight Replacement
Ce dont vous avez besoin
    1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: étape 1, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement, Garage Door: étape 1, image 2 de 2
      • Open the garage door by sliding both of the release buttons away from you.
      • Lift off the garage door.
      Demander à FixBot
      Ajouter un commentaire
    1. Shark Flex DuoClean LED Headlight Replacement, Side Component: étape 2, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement, Side Component: étape 2, image 2 de 2
      • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
      Demander à FixBot
    2. Shark Flex DuoClean LED Headlight Replacement: étape 3, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement: étape 3, image 2 de 2
      • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
      Demander à FixBot
    3. Shark Flex DuoClean LED Headlight Replacement: étape 4, image 1 de 1
      • Use the iFixit Opening Tool to pry the side of the vacuum open.
      Demander à FixBot
    4. Shark Flex DuoClean LED Headlight Replacement: étape 5, image 1 de 1
      • Remove the side component with your hands.
      Demander à FixBot
    1. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: étape 6, image 1 de 1
      Demander à FixBot
    2. Shark Flex DuoClean LED Headlight Replacement: étape 7, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement: étape 7, image 2 de 2
      • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
      • Prying off the cover too aggressively may cause it to break.
      Demander à FixBot
    3. Shark Flex DuoClean LED Headlight Replacement: étape 8, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement: étape 8, image 2 de 2
      Demander à FixBot
    4. Shark Flex DuoClean LED Headlight Replacement: étape 9, image 1 de 2 Shark Flex DuoClean LED Headlight Replacement: étape 9, image 2 de 2
      • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
      • Prying the cover off too aggressively may cause it to break.
      Demander à FixBot
    5. Shark Flex DuoClean LED Headlight Replacement: étape 10, image 1 de 1
      • Use wire cutters to detach the black cables from the LEDs on both sides.
      • Strip 1 cm off the ends of the wires, using a wire stripper.
      • Solder the exposed wires to the new LEDs.
      • Use the soldering guide in the Introduction.
      Demander à FixBot
Samantha Mickelson
Membre depuis le 10/08/18
496 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S17-G5, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 membres
25 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 24
Total : 1,841
