Aller au contenu principal
Shield Plate and Rubber Strap Removal
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Shield Plate and Rubber Strap Removal, Uncover the back panel screws: étape 1, image 1 de 2 Shield Plate and Rubber Strap Removal, Uncover the back panel screws: étape 1, image 2 de 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Shield Plate and Rubber Strap Removal: étape 2, image 1 de 3 Shield Plate and Rubber Strap Removal: étape 2, image 2 de 3 Shield Plate and Rubber Strap Removal: étape 2, image 3 de 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Shield Plate and Rubber Strap Removal, Remove the back panel screws: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Shield Plate and Rubber Strap Removal, Unclip the back panel: étape 4, image 1 de 3 Shield Plate and Rubber Strap Removal, Unclip the back panel: étape 4, image 2 de 3 Shield Plate and Rubber Strap Removal, Unclip the back panel: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Shield Plate and Rubber Strap Removal: étape 5, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 5, image 2 de 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Shield Plate and Rubber Strap Removal, Remove the back panel: étape 6, image 1 de 3 Shield Plate and Rubber Strap Removal, Remove the back panel: étape 6, image 2 de 3 Shield Plate and Rubber Strap Removal, Remove the back panel: étape 6, image 3 de 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Shield Plate and Rubber Strap Removal: étape 7, image 1 de 3 Shield Plate and Rubber Strap Removal: étape 7, image 2 de 3 Shield Plate and Rubber Strap Removal: étape 7, image 3 de 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Shield Plate and Rubber Strap Removal, Remove the fan screws: étape 8, image 1 de 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Shield Plate and Rubber Strap Removal, Disconnect the fan cable: étape 9, image 1 de 3 Shield Plate and Rubber Strap Removal, Disconnect the fan cable: étape 9, image 2 de 3 Shield Plate and Rubber Strap Removal, Disconnect the fan cable: étape 9, image 3 de 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Shield Plate and Rubber Strap Removal, Remove the fan: étape 10, image 1 de 2 Shield Plate and Rubber Strap Removal, Remove the fan: étape 10, image 2 de 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Shield Plate and Rubber Strap Removal, Unlatch the base: étape 11, image 1 de 3 Shield Plate and Rubber Strap Removal, Unlatch the base: étape 11, image 2 de 3 Shield Plate and Rubber Strap Removal, Unlatch the base: étape 11, image 3 de 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Shield Plate and Rubber Strap Removal, Twist and remove the base: étape 12, image 1 de 3 Shield Plate and Rubber Strap Removal, Twist and remove the base: étape 12, image 2 de 3 Shield Plate and Rubber Strap Removal, Twist and remove the base: étape 12, image 3 de 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Shield Plate and Rubber Strap Removal, Remove the optical drive screws: étape 13, image 1 de 2 Shield Plate and Rubber Strap Removal, Remove the optical drive screws: étape 13, image 2 de 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Shield Plate and Rubber Strap Removal, Remove the vibration isolator: étape 14, image 1 de 3 Shield Plate and Rubber Strap Removal, Remove the vibration isolator: étape 14, image 2 de 3 Shield Plate and Rubber Strap Removal, Remove the vibration isolator: étape 14, image 3 de 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Shield Plate and Rubber Strap Removal, Disconnect the power and data cables: étape 15, image 1 de 3 Shield Plate and Rubber Strap Removal, Disconnect the power and data cables: étape 15, image 2 de 3 Shield Plate and Rubber Strap Removal, Disconnect the power and data cables: étape 15, image 3 de 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Shield Plate and Rubber Strap Removal, Remove the optical drive: étape 16, image 1 de 2 Shield Plate and Rubber Strap Removal, Remove the optical drive: étape 16, image 2 de 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Shield Plate and Rubber Strap Removal, Disconnect the USB port cable: étape 17, image 1 de 3 Shield Plate and Rubber Strap Removal, Disconnect the USB port cable: étape 17, image 2 de 3 Shield Plate and Rubber Strap Removal, Disconnect the USB port cable: étape 17, image 3 de 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Shield Plate and Rubber Strap Removal: étape 18, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 18, image 2 de 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Shield Plate and Rubber Strap Removal, Disconnect the power button cable: étape 19, image 1 de 3 Shield Plate and Rubber Strap Removal, Disconnect the power button cable: étape 19, image 2 de 3 Shield Plate and Rubber Strap Removal, Disconnect the power button cable: étape 19, image 3 de 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Shield Plate and Rubber Strap Removal, Remove the chassis screws: étape 20, image 1 de 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Shield Plate and Rubber Strap Removal, Peel up the USB port cable: étape 21, image 1 de 2 Shield Plate and Rubber Strap Removal, Peel up the USB port cable: étape 21, image 2 de 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Shield Plate and Rubber Strap Removal, Remove the center chassis assembly: étape 22, image 1 de 3 Shield Plate and Rubber Strap Removal, Remove the center chassis assembly: étape 22, image 2 de 3 Shield Plate and Rubber Strap Removal, Remove the center chassis assembly: étape 22, image 3 de 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Shield Plate and Rubber Strap Removal, Unlatch the chassis strap: étape 23, image 1 de 3 Shield Plate and Rubber Strap Removal, Unlatch the chassis strap: étape 23, image 2 de 3 Shield Plate and Rubber Strap Removal, Unlatch the chassis strap: étape 23, image 3 de 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Shield Plate and Rubber Strap Removal: étape 24, image 1 de 3 Shield Plate and Rubber Strap Removal: étape 24, image 2 de 3 Shield Plate and Rubber Strap Removal: étape 24, image 3 de 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Shield Plate and Rubber Strap Removal, Remove the power cable port: étape 25, image 1 de 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Shield Plate and Rubber Strap Removal: étape 26, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 26, image 2 de 2
    • Lift the power connector out of its recess in the chassis.
  27. Shield Plate and Rubber Strap Removal, De-route the power cables: étape 27, image 1 de 2 Shield Plate and Rubber Strap Removal, De-route the power cables: étape 27, image 2 de 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Shield Plate and Rubber Strap Removal: étape 28, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 28, image 2 de 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Shield Plate and Rubber Strap Removal, Remove the corner cover: étape 29, image 1 de 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Shield Plate and Rubber Strap Removal: étape 30, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 30, image 2 de 2
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Shield Plate and Rubber Strap Removal, Remove the accessory antenna board: étape 31, image 1 de 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Shield Plate and Rubber Strap Removal: étape 32, image 1 de 3 Shield Plate and Rubber Strap Removal: étape 32, image 2 de 3 Shield Plate and Rubber Strap Removal: étape 32, image 3 de 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Shield Plate and Rubber Strap Removal, Remove the board shield: étape 33, image 1 de 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Shield Plate and Rubber Strap Removal: étape 34, image 1 de 3 Shield Plate and Rubber Strap Removal: étape 34, image 2 de 3 Shield Plate and Rubber Strap Removal: étape 34, image 3 de 3
    • Lift up the board shield to remove it from the center chassis.
  35. Shield Plate and Rubber Strap Removal, Remove the chassis strap: étape 35, image 1 de 3 Shield Plate and Rubber Strap Removal, Remove the chassis strap: étape 35, image 2 de 3 Shield Plate and Rubber Strap Removal, Remove the chassis strap: étape 35, image 3 de 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Shield Plate and Rubber Strap Removal: étape 36, image 1 de 2 Shield Plate and Rubber Strap Removal: étape 36, image 2 de 2
    • Remove the chassis strap.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Carsten Frauenheim
Membre depuis le 03/10/20
135 606 Réputation
371 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 434 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 8
Total : 39
