Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Skil 88 Motor Replacement
Ce dont vous avez besoin
    1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: étape 1, image 1 de 1
      • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
      Demander à FixBot
      Ajouter un commentaire
    2. Skil 88 Motor Replacement: étape 2, image 1 de 2 Skil 88 Motor Replacement: étape 2, image 2 de 2
      • Pull the front housing apart from the rear.
      • The motor and gears might fall out when you are pulling it apart.
      Demander à FixBot
    1. Skil 88 Motor Replacement, Motor: étape 3, image 1 de 2 Skil 88 Motor Replacement, Motor: étape 3, image 2 de 2
      • Remove the gear that is threaded onto the divider.
      Demander à FixBot
    2. Skil 88 Motor Replacement: étape 4, image 1 de 2 Skil 88 Motor Replacement: étape 4, image 2 de 2
      • Remove the divider from the rear housing.
      • The motor may come out along with the divider.
      Demander à FixBot
    3. Skil 88 Motor Replacement: étape 5, image 1 de 2 Skil 88 Motor Replacement: étape 5, image 2 de 2
      • Pull out the motor.
      Demander à FixBot
    4. Skil 88 Motor Replacement: étape 6, image 1 de 3 Skil 88 Motor Replacement: étape 6, image 2 de 3 Skil 88 Motor Replacement: étape 6, image 3 de 3
      Outil utilisé dans cette étape :
      • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
      • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
      • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
      Demander à FixBot
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membre depuis le 10/10/10
365 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 33
Total : 1,089
