Aller au contenu principal
Sonos Roam Inner Circuit Board Replacement
Ce dont vous avez besoin
  1. Sonos Roam Inner Circuit Board Replacement, End Caps: étape 1, image 1 de 3 Sonos Roam Inner Circuit Board Replacement, End Caps: étape 1, image 2 de 3 Sonos Roam Inner Circuit Board Replacement, End Caps: étape 1, image 3 de 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Inner Circuit Board Replacement: étape 2, image 1 de 2 Sonos Roam Inner Circuit Board Replacement: étape 2, image 2 de 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Inner Circuit Board Replacement, Speaker Grille: étape 3, image 1 de 2 Sonos Roam Inner Circuit Board Replacement, Speaker Grille: étape 3, image 2 de 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Inner Circuit Board Replacement: étape 4, image 1 de 2 Sonos Roam Inner Circuit Board Replacement: étape 4, image 2 de 2
    • Flip the device.
  5. Sonos Roam Inner Circuit Board Replacement: étape 5, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 5, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 5, image 3 de 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Inner Circuit Board Replacement, Speaker Module: étape 6, image 1 de 2 Sonos Roam Inner Circuit Board Replacement, Speaker Module: étape 6, image 2 de 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Inner Circuit Board Replacement: étape 7, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 7, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: étape 8, image 1 de 2 Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: étape 8, image 2 de 2
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Inner Circuit Board Replacement: étape 9, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 9, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 9, image 3 de 3
    J'achète
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Inner Circuit Board Replacement: étape 10, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 10, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 10, image 3 de 3
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Inner Circuit Board Replacement: étape 11, image 1 de 2 Sonos Roam Inner Circuit Board Replacement: étape 11, image 2 de 2
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
  12. Sonos Roam Inner Circuit Board Replacement, Battery: étape 12, image 1 de 2 Sonos Roam Inner Circuit Board Replacement, Battery: étape 12, image 2 de 2
  13. Sonos Roam Inner Circuit Board Replacement: étape 13, image 1 de 2 Sonos Roam Inner Circuit Board Replacement: étape 13, image 2 de 2
    J'achète
    • Use the tweezers to firmly squeeze the middle of the plug.
    • Pull the plug out to remove it from its socket.
    • Remove the battery from the device.
  14. Sonos Roam Inner Circuit Board Replacement: étape 14, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 14, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 14, image 3 de 3
    • Use the iFixit opening tool to pry the battery out of its casing.
    • Use the iOpener, blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  15. Sonos Roam Inner Circuit Board Replacement: étape 15, image 1 de 1
    • Remove the battery from its casing.
  16. Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: étape 16, image 1 de 2 Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: étape 16, image 2 de 2
    • Use the TR9 Torx screwdriver to remove the two 5 mm screws.
  17. Sonos Roam Inner Circuit Board Replacement: étape 17, image 1 de 3 Sonos Roam Inner Circuit Board Replacement: étape 17, image 2 de 3 Sonos Roam Inner Circuit Board Replacement: étape 17, image 3 de 3
    J'achète
    • Use the tweezers to firmly squeeze the center of the plug.
    • Grab the metal box to remove the inner circuit board.
Lauren Young
Membre depuis le 09/20/23
614 Réputation
5 tutoriels rédigés
Équipe
Utah Tech University, Team 1-2, McMurrin Fall 2023 Membre de l'équipe Utah Tech University, Team 1-2, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G2
3 membres
10 tutoriels rédigés
3 commentaires
Danke für die Anleitung.
Ich müsste die Leiterplatte auch tauschen. Weiß jemand, wo es noch passenden Ersatz gibt?
Danyel Bürgel - Réponse
Vielleicht hier?
VauWeh -
Danke aber das hatte ich schon versucht. Bietet man nicht an. Ich kann den Fehler eingrenzen aber den Chip bekomme ich leider auch nirgends.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 46
Total : 200
