Aller au contenu principal
Sonos Roam Speaker Module Replacement
Ce dont vous avez besoin
  1. Sonos Roam Speaker Module Replacement, End Caps: étape 1, image 1 de 3 Sonos Roam Speaker Module Replacement, End Caps: étape 1, image 2 de 3 Sonos Roam Speaker Module Replacement, End Caps: étape 1, image 3 de 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Speaker Module Replacement: étape 2, image 1 de 2 Sonos Roam Speaker Module Replacement: étape 2, image 2 de 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Speaker Module Replacement, Speaker Grille: étape 3, image 1 de 2 Sonos Roam Speaker Module Replacement, Speaker Grille: étape 3, image 2 de 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Speaker Module Replacement: étape 4, image 1 de 2 Sonos Roam Speaker Module Replacement: étape 4, image 2 de 2
    • Flip the device.
  5. Sonos Roam Speaker Module Replacement: étape 5, image 1 de 3 Sonos Roam Speaker Module Replacement: étape 5, image 2 de 3 Sonos Roam Speaker Module Replacement: étape 5, image 3 de 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Speaker Module Replacement, Speaker Module: étape 6, image 1 de 2 Sonos Roam Speaker Module Replacement, Speaker Module: étape 6, image 2 de 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Speaker Module Replacement: étape 7, image 1 de 3 Sonos Roam Speaker Module Replacement: étape 7, image 2 de 3 Sonos Roam Speaker Module Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
Lauren Young
Membre depuis le 09/20/23
614 Réputation
5 tutoriels rédigés
Équipe
Utah Tech University, Team 1-2, McMurrin Fall 2023 Membre de l'équipe Utah Tech University, Team 1-2, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G2
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 23
30 derniers jours : 86
Total : 404
