Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony BDP-S1 Fan Replacement
Ce dont vous avez besoin
    1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: étape 1, image 1 de 2 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: étape 1, image 2 de 2
      • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
      • Don't forget, there are two more 12mm screws on the other side as well.
      Demander à FixBot
      Ajouter un commentaire
    2. Sony BDP-S1 Fan Replacement: étape 2, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 2, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 2, image 3 de 3
      • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
      • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
      • Lastly, remove the three 12mm black screws on each side of device.
      Demander à FixBot
    3. Sony BDP-S1 Fan Replacement: étape 3, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 3, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 3, image 3 de 3
      • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
      • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
      Demander à FixBot
    4. Sony BDP-S1 Fan Replacement: étape 4, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 4, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 4, image 3 de 3
      • After the top is off, you'll see that there are two metal bars that go across the top of the device.
      • Remove each bar by unscrewing the two 10mm silver screws on each end.
      Demander à FixBot
    1. Sony BDP-S1 Fan Replacement, Fan: étape 5, image 1 de 3 Sony BDP-S1 Fan Replacement, Fan: étape 5, image 2 de 3 Sony BDP-S1 Fan Replacement, Fan: étape 5, image 3 de 3
      • First we need to unscrew the fan from before we can remove it.
      • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
      • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
      • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
      Demander à FixBot
    2. Sony BDP-S1 Fan Replacement: étape 6, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 6, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 6, image 3 de 3
      • We will now completely remove the fan from the player.
      • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
      • You are now ready to install the new fan!
      Demander à FixBot
Nicolas Kennedy
Membre depuis le 01/26/14
111 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-30, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-30, Maness Winter 2014
CPSU-MANESS-W14S9G30
3 membres
15 tutoriels rédigés
2 commentaires de tutoriel
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - Réponse Partager
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 44
Total : 3,291
