Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony CFD-8 Front Panel Replacement
Ce dont vous avez besoin
    1. Sony CFD-8 Front Panel Replacement, Battery: étape 1, image 1 de 3 Sony CFD-8 Front Panel Replacement, Battery: étape 1, image 2 de 3 Sony CFD-8 Front Panel Replacement, Battery: étape 1, image 3 de 3
      • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
      • Be sure to unplug the boombox from the wall before attempting to open it for repair.
      Demander à FixBot
      Ajouter un commentaire
    2. Sony CFD-8 Front Panel Replacement: étape 2, image 1 de 2 Sony CFD-8 Front Panel Replacement: étape 2, image 2 de 2
      • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
      • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
      Demander à FixBot
    1. Sony CFD-8 Front Panel Replacement, Front Panel: étape 3, image 1 de 3 Sony CFD-8 Front Panel Replacement, Front Panel: étape 3, image 2 de 3 Sony CFD-8 Front Panel Replacement, Front Panel: étape 3, image 3 de 3
      • Hold the boombox handle at an angle to access the screws behind the CD player.
      • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
      Demander à FixBot
    2. Sony CFD-8 Front Panel Replacement: étape 4, image 1 de 2 Sony CFD-8 Front Panel Replacement: étape 4, image 2 de 2
      • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
      • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
      Demander à FixBot
    3. Sony CFD-8 Front Panel Replacement: étape 5, image 1 de 3 Sony CFD-8 Front Panel Replacement: étape 5, image 2 de 3 Sony CFD-8 Front Panel Replacement: étape 5, image 3 de 3
      • Gently separate the front panel from the back panel.
      • Remove the two connections holding the front panel to boombox.
      • One connection is located on the upper left hand side of the main circuit board.
      • The other is a large white strip slightly to the right of the cassette player.
      • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
      • Remove the front panel.
      Demander à FixBot
3 autres ont terminé cette réparation.
Andrew Kleve
Membre depuis le 10/12/14
271 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 membres
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 49
Total : 4,226
