Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony ICF-C1T Screen Replacement
Ce dont vous avez besoin
    1. Sony ICF-C1T Screen Replacement, Screen: étape 1, image 1 de 1
      • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
      • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
      Demander à FixBot
      Ajouter un commentaire
    2. Sony ICF-C1T Screen Replacement: étape 2, image 1 de 1
      • Insert the plastic opening tool to pry apart the top and sides of the device gently.
      Demander à FixBot
    3. Sony ICF-C1T Screen Replacement: étape 3, image 1 de 2 Sony ICF-C1T Screen Replacement: étape 3, image 2 de 2
      • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
      • Pull the top of the device away from the rest of the clock to expose the inside.
      Demander à FixBot
    4. Sony ICF-C1T Screen Replacement: étape 4, image 1 de 2 Sony ICF-C1T Screen Replacement: étape 4, image 2 de 2
      • Do not use too much pressure on the plastic to not break it.
      • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
      • Use the plastic opening tool to separate the screen from the device.
      Demander à FixBot
    5. Sony ICF-C1T Screen Replacement: étape 5, image 1 de 2 Sony ICF-C1T Screen Replacement: étape 5, image 2 de 2
      • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
      • Another way to solve the brightness problem is to apply a tinted color sheet protector.
      Demander à FixBot
amber woolery
Membre depuis le 01/30/15
307 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 49
Total : 5,678
