Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony PlayStation 3D Display Control Buttons Replacement
Ce dont vous avez besoin
    1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: étape 1, image 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: étape 1, image 2 de 2
      • Remove the base by pushing in the button and sliding out the unit.
      Demander à FixBot
      Ajouter un commentaire
    2. Sony PlayStation 3D Display Control Buttons Replacement: étape 2, image 1 de 3 Sony PlayStation 3D Display Control Buttons Replacement: étape 2, image 2 de 3 Sony PlayStation 3D Display Control Buttons Replacement: étape 2, image 3 de 3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      Demander à FixBot
    3. Sony PlayStation 3D Display Control Buttons Replacement: étape 3, image 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement: étape 3, image 2 de 2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      Demander à FixBot
    4. Sony PlayStation 3D Display Control Buttons Replacement: étape 4, image 1 de 3 Sony PlayStation 3D Display Control Buttons Replacement: étape 4, image 2 de 3 Sony PlayStation 3D Display Control Buttons Replacement: étape 4, image 3 de 3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      Demander à FixBot
    1. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: étape 5, image 1 de 1
      • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
      Demander à FixBot
    2. Sony PlayStation 3D Display Control Buttons Replacement: étape 6, image 1 de 2 Sony PlayStation 3D Display Control Buttons Replacement: étape 6, image 2 de 2
      • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
      Demander à FixBot
Tia McNaughton
Membre depuis le 10/01/15
379 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-16, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 989
