Aller au contenu principal
Sony SRS-XE200 Speaker Assembly Replacement
Ce dont vous avez besoin
  1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: étape 1, image 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: étape 1, image 2 de 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Speaker Assembly Replacement: étape 2, image 1 de 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Speaker Assembly Replacement: étape 3, image 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement: étape 3, image 2 de 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Speaker Assembly Replacement: étape 4, image 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement: étape 4, image 2 de 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
Kristen Gismondi
Membre depuis le 11/12/14
92 197 Réputation
241 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 475 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 258
