Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony Xperia TL Display Assembly Replacement
Ce dont vous avez besoin
  1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: étape 1, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: étape 1, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: étape 1, image 3 de 3
    • Use the plastic opening tool to pry the top plastic section off.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: étape 2, image 1 de 2 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: étape 2, image 2 de 2
    • Use the plastic opening tool to pry the bottom plastic section off.
    Demander à FixBot
  3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: étape 3, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: étape 3, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: étape 3, image 3 de 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
    Demander à FixBot
  4. Sony Xperia TL Display Assembly Replacement, Loud Speaker: étape 4, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: étape 4, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: étape 4, image 3 de 3
    • Use the plastic opening tool to remove the loud speaker module.
    Demander à FixBot
  5. Sony Xperia TL Display Assembly Replacement, Battery: étape 5, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Battery: étape 5, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Battery: étape 5, image 3 de 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    Demander à FixBot
  6. Sony Xperia TL Display Assembly Replacement, Battery Harness: étape 6, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: étape 6, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: étape 6, image 3 de 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
    Demander à FixBot
  7. Sony Xperia TL Display Assembly Replacement: étape 7, image 1 de 1
    • The final step is taking the entire harness off of the phone.
    Demander à FixBot
  8. Sony Xperia TL Display Assembly Replacement, Motherboard: étape 8, image 1 de 3 Sony Xperia TL Display Assembly Replacement, Motherboard: étape 8, image 2 de 3 Sony Xperia TL Display Assembly Replacement, Motherboard: étape 8, image 3 de 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
    Demander à FixBot
  9. Sony Xperia TL Display Assembly Replacement, Ear Speaker: étape 9, image 1 de 1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
    Demander à FixBot
  10. Sony Xperia TL Display Assembly Replacement, Display Assembly: étape 10, image 1 de 1
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
    Demander à FixBot
Adam Giniger
Membre depuis le 09/22/14
1 303 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 4-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 membres
20 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 31
Total : 880
