Aller au contenu principal
Sony Xperia XA1 Battery Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: étape 1, image 1 de 3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: étape 1, image 2 de 3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: étape 1, image 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Battery Replacement, Battery: étape 2, image 1 de 2 Sony Xperia XA1 Battery Replacement, Battery: étape 2, image 2 de 2
    • Disconnect the battery from the motherboard using an opening tool or spudger.
  3. Sony Xperia XA1 Battery Replacement: étape 3, image 1 de 3 Sony Xperia XA1 Battery Replacement: étape 3, image 2 de 3 Sony Xperia XA1 Battery Replacement: étape 3, image 3 de 3
    • Lift the black tabs on either side of the battery
  4. Sony Xperia XA1 Battery Replacement: étape 4, image 1 de 3 Sony Xperia XA1 Battery Replacement: étape 4, image 2 de 3 Sony Xperia XA1 Battery Replacement: étape 4, image 3 de 3
    • Lift the pull tab at the bottom to unseat the battery.
    • After unseating the battery with the pull tab, lift it out of the case.
    • Use caution handling the battery. It is extremely delicate.
  5. Sony Xperia XA1 Battery Replacement: étape 5, image 1 de 2 Sony Xperia XA1 Battery Replacement: étape 5, image 2 de 2
    • Remove the battery entirely.
    • Do not dispose of your old battery in a regular trash can. Please bring your phone battery to a local home depot, best buy, or staples for safe disposal and recycling in the US and Canada. Other places in the world, please contact your local recycling centers.
Lindsey Taysom
Membre depuis le 02/14/23
205 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 48
Total : 521
