Introduction
Use this guide to replace the left trigger assembly (L2) on your Steam Deck LCD. Although nearly identical, the procedure for the right trigger (R2) can be found here.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Replacement triggers require calibration to work as expected. Read about how to do that here.
Ce dont vous avez besoin
Power down your Steam Deck and unplug any cables.
Outil utilisé dans cette étape :FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Place the flat end of a spudger onto the inside edge of the trigger's left clip.
Pivot the trigger clip out, away, and up from the peg to unlatch it.
Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
6 autres ont terminé cette réparation.
4 commentaires
Ich brauche dringend die l2 Trigger Taste und warte auf Verfügbarkeit! Wie lange dauert es und muss ich die Seite immer aktuell besuchen um heraus zu finden ob das Ersatzteil verfügbar ist?
Same here. Wann ist mit einer Verfügbarkeit zu Rechnen?
Markus R -
Bought L2 replacement but it did not come with the spring that is required to replace it. Who do I contact for that?
