Introduction
Use this guide to replace the quick access button in your Steam Deck OLED.
Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Ce dont vous avez besoin
Power down your Steam Deck and unplug any cables.
Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
Slide your pick along the edge of the handle to release the clips securing it to the front shell.
Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
Remove the back cover.
Grip the battery cable pull tab, located to the left of the battery.
Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
During disassembly, skip the next three steps.
Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
Reconnect the interconnect cable ZIF connector.
Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
Flip up the small black locking flap on the right thumbstick cable ZIF connector.
Slide the connector straight out of its socket to disconnect it.
Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
The touchpad cable
The touchpad board cable
The action buttons and menu button cable
Insert the point of your spudger under the neck of the haptics cable connector.
Gently pry up to disconnect it.
Use your T6 Torx driver to remove the four screws securing the right button board:
Two 5.9 mm‑long screws
One 3.8 mm‑long screw
One 4.9 mm‑long screw
Insert the point of your spudger between the bottom left corner of the button board and the frame.
Pry up until you can grab the button board with your fingers.
Remove the button board.
Use tweezers to remove the quick access button membrane.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
