Introduction
Use this guide to replace the charging port on your SteelSeries Stratus Duo.
Ce dont vous avez besoin
Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
Use the opening pick to carefully pry up the battery and separate the adhesive.
Grab the battery with your fingers and lift it out of its recess to remove it.
Use a Phillips screwdriver to remove the two 7.2 mm-long screws securing the plastic bracket that holds the charging port and the Bluetooth/power buttons in place.
Use your fingers to push the plastic bracket downwards into the recess of the battery to loosen it.
Remove the plastic bracket.
Repair didn’t go as planned? Ask our Answers community for help.
Un commentaire
Where can i get the replacement board? Stratus is not responding to my messages.
