Ce dont vous avez besoin
The screws can now be removed from the battery with a screwdriver PH 3 (alternatively a wrench or a socket wrench size 10 can be used).
Attention! There are nuts under the screws. These are not attached, so care must be taken when removing the screws that the nuts are not lost.
Before installation, both battery poles should be treated with polar grease or polish spray. Otherwise it can lead to corrosion, which can lead to contact problems.
To put the device back together follow the steps in reverse order.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
