Aller au contenu principal
Pour réparer ensemble - Je crée un compte
SwagTron T1 Gyroscope Replacement
Ce dont vous avez besoin
  1. SwagTron T1 Gyroscope Replacement, Back Panels: étape 1, image 1 de 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
    Demander à FixBot
    Ajouter un commentaire
  2. SwagTron T1 Gyroscope Replacement: étape 2, image 1 de 3 SwagTron T1 Gyroscope Replacement: étape 2, image 2 de 3 SwagTron T1 Gyroscope Replacement: étape 2, image 3 de 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
    Demander à FixBot
  3. SwagTron T1 Gyroscope Replacement: étape 3, image 1 de 3 SwagTron T1 Gyroscope Replacement: étape 3, image 2 de 3 SwagTron T1 Gyroscope Replacement: étape 3, image 3 de 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
    Demander à FixBot
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: étape 4, image 1 de 2 SwagTron T1 Gyroscope Replacement, Gyroscope: étape 4, image 2 de 2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
    Demander à FixBot
  5. SwagTron T1 Gyroscope Replacement: étape 5, image 1 de 1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
    Demander à FixBot
  6. SwagTron T1 Gyroscope Replacement: étape 6, image 1 de 3 SwagTron T1 Gyroscope Replacement: étape 6, image 2 de 3 SwagTron T1 Gyroscope Replacement: étape 6, image 3 de 3
    • Carefully remove the gyroscope component from the SwagTron.
    Demander à FixBot
9 autres ont terminé cette réparation.
Teagan Allen
Membre depuis le 04/18/17
432 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G5, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 membres
5 tutoriels rédigés
5 commentaires de tutoriel
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Réponse Partager
Amazon.com Keyword: CertiCable
Jesse Griffis - Réponse Partager
Where do you get the replacement?
Brittany Conner - Réponse Partager
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Réponse Partager
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 69
Total : 8,327
