Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Swagtron T3 Gyroscope Replacement
Ce dont vous avez besoin
    1. Swagtron T3 Gyroscope Replacement, Cover: étape 1, image 1 de 2 Swagtron T3 Gyroscope Replacement, Cover: étape 1, image 2 de 2
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Demander à FixBot
      Ajouter un commentaire
    2. Swagtron T3 Gyroscope Replacement: étape 2, image 1 de 3 Swagtron T3 Gyroscope Replacement: étape 2, image 2 de 3 Swagtron T3 Gyroscope Replacement: étape 2, image 3 de 3
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Demander à FixBot
    1. Swagtron T3 Gyroscope Replacement, Gyroscope: étape 3, image 1 de 1
      • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
      • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
      • Three red and black cables with white connectors.
      • One multicolored cable with a black connector.
      Demander à FixBot
    2. Swagtron T3 Gyroscope Replacement: étape 4, image 1 de 1
      • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
      Demander à FixBot
    3. Swagtron T3 Gyroscope Replacement: étape 5, image 1 de 2 Swagtron T3 Gyroscope Replacement: étape 5, image 2 de 2
      • Cut the plastic cable tie holding the cables together with utility scissors.
      • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
      Demander à FixBot
    4. Swagtron T3 Gyroscope Replacement: étape 6, image 1 de 1
      • Gently lift the blue gyroscope off of the white plastic holder piece.
      • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
      • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
      Demander à FixBot
3 autres ont terminé cette réparation.
Emily Richter
Membre depuis le 04/10/17
351 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S13-G3, Forte Spring 2017 Membre de l'équipe Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 membres
24 tutoriels rédigés
3 commentaires de tutoriel
Where can one buy the new gyroscope?
Mike - Réponse Partager
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
where can I buy new gyroscope
roccovalletta - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 43
Total : 5,556
