Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sweatshirt Hoodie Grommets Replacement
Ce dont vous avez besoin
  1. Sweatshirt Hoodie Grommets Replacement, Grommets: étape 1, image 1 de 2 Sweatshirt Hoodie Grommets Replacement, Grommets: étape 1, image 2 de 2
    • Grab the end of the hoodie of the string.
    • Pull the string towards yourself until it is out of the hoodie completely.
    Demander à FixBot
    Ajouter un commentaire
  2. Sweatshirt Hoodie Grommets Replacement: étape 2, image 1 de 3 Sweatshirt Hoodie Grommets Replacement: étape 2, image 2 de 3 Sweatshirt Hoodie Grommets Replacement: étape 2, image 3 de 3
    • Use the seam ripper to tear the seam on the hoodie open.
    • Use scissors as necessary to cut excess thread.
    • Continue this process until the seam is open enough to put the grommet tool in. There should be a hole about 1"-2" long.
    • Seam ripper may cause injury if handled incorrectly.
    Demander à FixBot
  3. Sweatshirt Hoodie Grommets Replacement: étape 3, image 1 de 1
    • Place the top section of the grommet over the desired hole.
    Demander à FixBot
  4. Sweatshirt Hoodie Grommets Replacement: étape 4, image 1 de 2 Sweatshirt Hoodie Grommets Replacement: étape 4, image 2 de 2
    • Flip the hole over and place the bottom piece of the grommet over the cylindrical section of the top piece.
    • Grab your grommet pliers and locate the side with the cone shaped nub. Make sure that the side with the nub is facing against the bottom piece of the grommet.
    Demander à FixBot
  5. Sweatshirt Hoodie Grommets Replacement: étape 5, image 1 de 2 Sweatshirt Hoodie Grommets Replacement: étape 5, image 2 de 2
    • Align the grommet pliers with both pieces of the grommet.
    • Squeeze the pliers with moderate pressure until the grommet becomes attached to the hoodie securely.
    Demander à FixBot
  6. Sweatshirt Hoodie Grommets Replacement: étape 6, image 1 de 1
    • Thread a sewing needle with matching colored thread to mend the ripped area.
    • Follow How to Use a Needle Threader if you are unsure how to do this.
    Demander à FixBot
  7. Sweatshirt Hoodie Grommets Replacement: étape 7, image 1 de 3 Sweatshirt Hoodie Grommets Replacement: étape 7, image 2 de 3 Sweatshirt Hoodie Grommets Replacement: étape 7, image 3 de 3
    • Re-attach the ripped area using your preferred sewing technique.
    • Use a scissor to cut off excess threads after finish sewing.
    • Follow How to Hand Sew A Small Hole in Clothing if you are unsure how to do this.
    Demander à FixBot
  8. Sweatshirt Hoodie Grommets Replacement: étape 8, image 1 de 1
    Demander à FixBot
Ligne d'arrivée
Haiming Dong
Membre depuis le 01/31/24
157 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-5, Andersen Winter 2024 Membre de l'équipe UC Davis, Team 4-5, Andersen Winter 2024
UCD-ANDERSEN-W24S4G5
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 25
30 derniers jours : 126
Total : 1,932
