Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Syma S107 Gyro Replacement
Ce dont vous avez besoin
    1. Syma S107 Gyro Replacement, Counterweight Bar: étape 1, image 1 de 2 Syma S107 Gyro Replacement, Counterweight Bar: étape 1, image 2 de 2
      Outil utilisé dans cette étape :
      • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
      Demander à FixBot
      Ajouter un commentaire
    2. Syma S107 Gyro Replacement: étape 2, image 1 de 2 Syma S107 Gyro Replacement: étape 2, image 2 de 2
      • Remove the counterweight bar by removing the screw.
      • One 10.1mm Phillips #0.
      Demander à FixBot
    3. Syma S107 Gyro Replacement, Gyro Carriage: étape 3, image 1 de 2 Syma S107 Gyro Replacement, Gyro Carriage: étape 3, image 2 de 2
      • Remove the gyro carriage by removing the following screws:
      • Two 5.6mm Phillips #0.
      • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
      Demander à FixBot
    4. Syma S107 Gyro Replacement: étape 4, image 1 de 2 Syma S107 Gyro Replacement: étape 4, image 2 de 2
      • Gently remove the broken gyro carriage by pulling up.
      • Remove blade assembly by simply sliding it up and off the shaft.
      Demander à FixBot
    5. Syma S107 Gyro Replacement, Blade Carriage: étape 5, image 1 de 3 Syma S107 Gyro Replacement, Blade Carriage: étape 5, image 2 de 3 Syma S107 Gyro Replacement, Blade Carriage: étape 5, image 3 de 3
      • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
      Demander à FixBot
    6. Syma S107 Gyro Replacement: étape 6, image 1 de 2 Syma S107 Gyro Replacement: étape 6, image 2 de 2
      • Remove the blades from the blade carriage by removing the following screws:
      • Two 4.7mm Phillips #0.
      Demander à FixBot
    7. Syma S107 Gyro Replacement: étape 7, image 1 de 2 Syma S107 Gyro Replacement: étape 7, image 2 de 2
      • Remove the following screws:
      • Two 4.5mm Phillips #0.
      • Make sure to remove any broken plastic pins before reassembling the components.
      • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
      Demander à FixBot
7 autres ont terminé cette réparation.
Christopher Smith
Membre depuis le 10/11/14
305 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-31, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 membre
11 tutoriels rédigés
6 commentaires de tutoriel
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Réponse Partager
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Réponse Partager
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Réponse Partager
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Réponse Partager
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 26
30 derniers jours : 105
Total : 15,984
