Introduction
Is your Teddy Ruxpin story-time mood or singing not working? Your Teddy Ruxpin’s arm buttons might need to be replaced! This guide will take you through the proper steps on how to remove the buttons with ease. For this guide, all you will need is a pair of scissors and a Phillips #1 and #2 screwdriver. There are not many difficult steps but pull the wires with caution as you do not want to break them.
Ce dont vous avez besoin
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
4 autres ont terminé cette réparation.
4 commentaires de tutoriel
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
And how do you replace it?! This just says how to take out old buttons!
So has anyone figured out how to replace the button?
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
