Aller au contenu principal
Pour réparer ensemble - Je crée un compte
TomTom One XL Screen Replacement
Ce dont vous avez besoin
    1. TomTom One XL Screen Replacement, Back Panel: étape 1, image 1 de 2 TomTom One XL Screen Replacement, Back Panel: étape 1, image 2 de 2
      • Remove the 4 .4mm screws on the back of the device.
      Demander à FixBot
      Ajouter un commentaire
    2. TomTom One XL Screen Replacement: étape 2, image 1 de 1
      • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
      • You can rotate TOMTOM XL to make prying back off easier.
      • Be careful not to injure the two wires connecting the pieces.
      Demander à FixBot
    3. TomTom One XL Screen Replacement: étape 3, image 1 de 1
      • After prying both halves apart, they will be connected by two wires.
      • Carefully set the two halves next to each other making sure not to stress or damage the wires.
      Demander à FixBot
    4. TomTom One XL Screen Replacement: étape 4, image 1 de 2 TomTom One XL Screen Replacement: étape 4, image 2 de 2
      Outil utilisé dans cette étape :
      • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
      • Be gentle while pulling the wires out, the plugs are easily injured.
      Demander à FixBot
    1. TomTom One XL Screen Replacement, Screen: étape 5, image 1 de 2 TomTom One XL Screen Replacement, Screen: étape 5, image 2 de 2
      • Locate the 4 .4mm screws connecting the circuit board to the front panel.
      • Use the T6 Torx screwdriver and remove the four screws.
      Demander à FixBot
    2. TomTom One XL Screen Replacement: étape 6, image 1 de 3 TomTom One XL Screen Replacement: étape 6, image 2 de 3 TomTom One XL Screen Replacement: étape 6, image 3 de 3
      • Locate the ribbon cable connecting the front panel to the circuit board.
      • Locate the white tab locking the ribbon in place.
      • Using precision tweezers push the left and right side of the tab forward.
      • Gently pull the ribbon to disconnect the circuit board from the front panel.
      • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
      Demander à FixBot
    3. TomTom One XL Screen Replacement: étape 7, image 1 de 3 TomTom One XL Screen Replacement: étape 7, image 2 de 3 TomTom One XL Screen Replacement: étape 7, image 3 de 3
      • Use the palate knife to pry the screen away from the front panel.
      • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
      • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
      Demander à FixBot
DeVhan
Membre depuis le 03/11/15
401 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 31
Total : 1,259
