Aller au contenu principal
Toshiba Satellite L55-A CMOS Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the RAM cover: étape 1, image 1 de 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A CMOS Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite L55-A CMOS Battery Replacement: étape 2, image 2 de 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 1 de 3 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 2 de 3 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: étape 3, image 3 de 3
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the back cover: étape 4, image 1 de 1
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A CMOS Battery Replacement: étape 5, image 1 de 3 Toshiba Satellite L55-A CMOS Battery Replacement: étape 5, image 2 de 3 Toshiba Satellite L55-A CMOS Battery Replacement: étape 5, image 3 de 3
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A CMOS Battery Replacement: étape 6, image 1 de 2 Toshiba Satellite L55-A CMOS Battery Replacement: étape 6, image 2 de 2
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A CMOS Battery Replacement: étape 7, image 1 de 3 Toshiba Satellite L55-A CMOS Battery Replacement: étape 7, image 2 de 3 Toshiba Satellite L55-A CMOS Battery Replacement: étape 7, image 3 de 3
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: étape 8, image 1 de 3 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: étape 8, image 2 de 3 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: étape 8, image 3 de 3
    • Use your fingernail or an opening pick to push the gold metal clip off of the top of the coin cell.
    • Pry the coin cell out of its holder and remove it.
    • To install a replacement battery, align the battery and press it firmly into the holder until the battery snaps into position.
Arthur Shi
Membre depuis le 01/03/18
282 203 Réputation
585 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 446 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 2,756
