Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tungsten E Disassembly
Ce dont vous avez besoin
    1. Tungsten E Disassembly, Tungsten E Disassembly: étape 1, image 1 de 2 Tungsten E Disassembly, Tungsten E Disassembly: étape 1, image 2 de 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Demander à FixBot
      Ajouter un commentaire
    2. Tungsten E Disassembly: étape 2, image 1 de 3 Tungsten E Disassembly: étape 2, image 2 de 3 Tungsten E Disassembly: étape 2, image 3 de 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Demander à FixBot
    3. Tungsten E Disassembly: étape 3, image 1 de 2 Tungsten E Disassembly: étape 3, image 2 de 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Demander à FixBot
    4. Tungsten E Disassembly: étape 4, image 1 de 2 Tungsten E Disassembly: étape 4, image 2 de 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Demander à FixBot
    5. Tungsten E Disassembly: étape 5, image 1 de 3 Tungsten E Disassembly: étape 5, image 2 de 3 Tungsten E Disassembly: étape 5, image 3 de 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Demander à FixBot
    6. Tungsten E Disassembly: étape 6, image 1 de 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Demander à FixBot
Kevin Hom
Membre depuis le 01/21/10
118 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-22, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
How does one unplug the battery?
dlcatftwin - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 50
Total : 8,584
