Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Turtle Beach Recon Controller Front Buttons Replacement
Ce dont vous avez besoin
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: étape 1, image 1 de 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: étape 1, image 2 de 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: étape 1, image 3 de 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    Demander à FixBot
    Ajouter un commentaire
  2. Turtle Beach Recon Controller Front Buttons Replacement: étape 2, image 1 de 3 Turtle Beach Recon Controller Front Buttons Replacement: étape 2, image 2 de 3 Turtle Beach Recon Controller Front Buttons Replacement: étape 2, image 3 de 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    Demander à FixBot
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: étape 3, image 1 de 2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: étape 3, image 2 de 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    Demander à FixBot
  4. Turtle Beach Recon Controller Front Buttons Replacement: étape 4, image 1 de 2 Turtle Beach Recon Controller Front Buttons Replacement: étape 4, image 2 de 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    Demander à FixBot
  5. Turtle Beach Recon Controller Front Buttons Replacement: étape 5, image 1 de 3 Turtle Beach Recon Controller Front Buttons Replacement: étape 5, image 2 de 3 Turtle Beach Recon Controller Front Buttons Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    Demander à FixBot
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: étape 6, image 1 de 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: étape 6, image 2 de 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: étape 6, image 3 de 3
    • Gently remove front buttons from the face plate by hand.
    Demander à FixBot
2 autres ont terminé cette réparation.
Mary Goodrow
Membre depuis le 03/22/24
716 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-1, Botvin Spring 2024 Membre de l'équipe UMass Dartmouth, Team 6-1, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 35
Total : 713
