Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Unbranded UB-15MS10 Back Camera Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
    Demander à FixBot
    Ajouter un commentaire
  2. Unbranded UB-15MS10 Back Camera Replacement: étape 2, image 1 de 1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
    Demander à FixBot
  3. Unbranded UB-15MS10 Back Camera Replacement: étape 3, image 1 de 2 Unbranded UB-15MS10 Back Camera Replacement: étape 3, image 2 de 2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
    Demander à FixBot
  4. Unbranded UB-15MS10 Back Camera Replacement: étape 4, image 1 de 1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
    Demander à FixBot
  5. Unbranded UB-15MS10 Back Camera Replacement: étape 5, image 1 de 1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
    Demander à FixBot
  6. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: étape 6, image 1 de 1
    • Remove the small piece of black tape.
    Demander à FixBot
  7. Unbranded UB-15MS10 Back Camera Replacement: étape 7, image 1 de 1
    • Remove the black 4-mm #0 screw.
    Demander à FixBot
  8. Unbranded UB-15MS10 Back Camera Replacement: étape 8, image 1 de 1
    • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
    • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
    Demander à FixBot
4 autres ont terminé cette réparation.
Jordan Turk
Membre depuis le 09/21/15
331 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Baechle Fall 2015 Membre de l'équipe IUPUI, Team 2-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G1
3 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 886
