Aller au contenu principal
Pour réparer ensemble - Je crée un compte
VHS Shell Replacement
Ce dont vous avez besoin
  1. VHS Shell Replacement, Plastic Shell: étape 1, image 1 de 2 VHS Shell Replacement, Plastic Shell: étape 1, image 2 de 2
    • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. VHS Shell Replacement: étape 2, image 1 de 1
    • Once the screws are out, pull off the front of the VHS shell.
    • Take off any labels on the sides of tape before doing this step.
    • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
    Demander à FixBot
  3. VHS Shell Replacement: étape 3, image 1 de 2 VHS Shell Replacement: étape 3, image 2 de 2
    • Hold down on the white lever.
    • While holding down, carefully take out the reel on the right.
    • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
    Demander à FixBot
  4. VHS Shell Replacement: étape 4, image 1 de 2 VHS Shell Replacement: étape 4, image 2 de 2
    • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
    • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
    Demander à FixBot
  5. VHS Shell Replacement: étape 5, image 1 de 1
    • Once the screws are out, pull off the front of the replacement shell.
    Demander à FixBot
  6. VHS Shell Replacement: étape 6, image 1 de 1
    • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
    • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
    Demander à FixBot
  7. VHS Shell Replacement: étape 7, image 1 de 1
    • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
    Demander à FixBot
  8. VHS Shell Replacement: étape 8, image 1 de 1
    • Turn the reels to retract any excess tape hanging out of the top.
    • This isn't a necessary step, just one that I prefer to do.
    Demander à FixBot
  9. VHS Shell Replacement: étape 9, image 1 de 1
    • Place the top of the replacement shell back on.
    Demander à FixBot
  10. VHS Shell Replacement: étape 10, image 1 de 1
    • Screw the screws back in with a screwdriver.
    Demander à FixBot
McKinley Hixon
Membre depuis le 03/19/21
202 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - Réponse Partager
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 118
Total : 3,868
