Introduction
The device LEDs help light the screen. This guide will assist you in removing them and replacing them.
Ce dont vous avez besoin
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Unscrew the two 7.3 mm screws using a PH0 driver head.
Gently lift the beige circuit board and set aside.
