Introduction
If the VTech VM3245 will not switch on, the battery may need to be replaced. The information below specifically states how to remove the battery and replace it with a new one. The only tools needed include a Phillips #00 screwdriver, Jimmy, and one opening pick. You will not have any difficult steps, but remove the front cover of the device attentively.
Ce dont vous avez besoin
Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
1 commentaire de tutoriel
What is the battery that needs to be replaced called?
