Introduction
If the camera stand is cracked or it seems to be unbalanced, you may need to replace it with a new one. Below are the following steps to replace the camera stand in order for there to be balance and it to stand securely.
Ce dont vous avez besoin
Unscrew and remove the two 8 mm Phillips #0 screws from the bottom of the stand.
Use the Jimmy tool to open the stand.
Remove the bottom of the stand.
