Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Voluas VL001 USB Replacement
Ce dont vous avez besoin
    1. Voluas VL001 USB Replacement, Storage Tank: étape 1, image 1 de 3 Voluas VL001 USB Replacement, Storage Tank: étape 1, image 2 de 3 Voluas VL001 USB Replacement, Storage Tank: étape 1, image 3 de 3
      • Remove the lid to the storage tank by using the latch and lifting off.
      • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
      Demander à FixBot
      Ajouter un commentaire
    1. Voluas VL001 USB Replacement, Battery: étape 2, image 1 de 3 Voluas VL001 USB Replacement, Battery: étape 2, image 2 de 3 Voluas VL001 USB Replacement, Battery: étape 2, image 3 de 3
      • Place your pet feeder upside down.
      • Squeeze the lock and remove the battery cover.
      • Remove the three 1.5V D alkaline batteries.
      Demander à FixBot
    1. Voluas VL001 USB Replacement, Housing: étape 3, image 1 de 3 Voluas VL001 USB Replacement, Housing: étape 3, image 2 de 3 Voluas VL001 USB Replacement, Housing: étape 3, image 3 de 3
      • Insert a metal spudger under the adhesive part of each rubber foot.
      • Pry the foot off.
      Demander à FixBot
    2. Voluas VL001 USB Replacement: étape 4, image 1 de 2 Voluas VL001 USB Replacement: étape 4, image 2 de 2
      • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
      • These holes were previously covered by the rubber feet.
      • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
      Demander à FixBot
    3. Voluas VL001 USB Replacement: étape 5, image 1 de 1
      • Turn the device over so it is oriented right-side up.
      • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
      Demander à FixBot
    1. Voluas VL001 USB Replacement, USB: étape 6, image 1 de 2 Voluas VL001 USB Replacement, USB: étape 6, image 2 de 2
      • Using a Phillips #2 screwdriver, carefully remove the two 11.2 mm screws on either side of the USB port.
      Demander à FixBot
    2. Voluas VL001 USB Replacement: étape 7, image 1 de 2 Voluas VL001 USB Replacement: étape 7, image 2 de 2
      • Using your wire strippers/pliers, cut the three wires that are connected to the USB port.
      Demander à FixBot
    3. Voluas VL001 USB Replacement: étape 8, image 1 de 3 Voluas VL001 USB Replacement: étape 8, image 2 de 3 Voluas VL001 USB Replacement: étape 8, image 3 de 3
      • Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
      • Because the wire is so thin, it can be easy to accidentally cut all the way through the wire on this step. Take care to only cut through the insulation.
      • You will want to see a score line in the insulation all around the wire like this.
      • Pull the end of the insulation off, exposing the wire.
      Demander à FixBot
    4. Voluas VL001 USB Replacement: étape 9, image 1 de 2 Voluas VL001 USB Replacement: étape 9, image 2 de 2
      • Put the exposed wire on the solder patch, making sure it has good contact with the metal.
      • Solder the wire on to the solder patch.
      • Repeat steps 8 and 9 for the other two wires.
      Demander à FixBot
Merari Aniga
Membre depuis le 01/30/24
459 Réputation
4 tutoriels rédigés
Équipe
Utah Tech University, Team 1-3, McMurrin Spring 2024 Membre de l'équipe Utah Tech University, Team 1-3, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G3
2 membres
11 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 14
30 derniers jours : 40
Total : 568
