Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Vtech Kidizoom Smart Watch DX Buttons Replacement
Ce dont vous avez besoin
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: étape 1, image 1 de 1
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
      Demander à FixBot
      Ajouter un commentaire
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 2, image 1 de 1
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
      Demander à FixBot
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 3, image 1 de 1
      • Gently pull the back plate from the watch casing.
      Demander à FixBot
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 4, image 1 de 2 Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 4, image 2 de 2
      • Lift the master switch from the circuit board.
      Demander à FixBot
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: étape 5, image 1 de 2 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: étape 5, image 2 de 2
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
      Demander à FixBot
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 6, image 1 de 1
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
      Demander à FixBot
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 7, image 1 de 1
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
      Demander à FixBot
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 8, image 1 de 1
      • De-solder the red speaker wire, as in the previous step.
      Demander à FixBot
    5. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 9, image 1 de 1
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
      Demander à FixBot
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: étape 10, image 1 de 1
      Outil utilisé dans cette étape :
      • Use the the tweezers to pull off the blue rubber cover behind the button.
      • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
      Demander à FixBot
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 11, image 1 de 1
      • Use tweezers to separate the backside tab from the front side of the button.
      Demander à FixBot
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: étape 12, image 1 de 1
      • Push the other half of the button out of the casing.
      • Repeat steps 11 and 12 for all buttons.
      Demander à FixBot
2 autres ont terminé cette réparation.
Équipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
Where can you buy the replacement cover?
Katrina Nullatamby - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 51
Total : 6,547
