Aller au contenu principal
Whirlpool Refrigerator Thermistor Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Thermistor Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Thermistor Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: étape 3, image 1 de 2 Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: étape 3, image 2 de 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: étape 4, image 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: étape 4, image 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: étape 4, image 3 de 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: étape 5, image 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: étape 5, image 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: étape 5, image 3 de 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Thermistor Replacement, Remove the assembly: étape 6, image 1 de 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: étape 7, image 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: étape 7, image 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: étape 7, image 3 de 3
    • Disconnect any connectors attached to the thermistor.
  8. Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: étape 8, image 1 de 2 Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: étape 8, image 2 de 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
  9. Whirlpool Refrigerator Thermistor Replacement, Meter the thermistor: étape 9, image 1 de 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
700 tutoriels rédigés
4 commentaires
Great article. I have a question: My Kenmore refrigerator stopped cooling. I noticed that the compressor and fan were not operating but the evap fan was. I get no power to the compressor or fan. I replaced the start capacitor and start relay with a 3 in 1 start capacitor. Still nothing. I decided to wire the new 3 in 1 and fan with a separate AC wire directly to an outlet. This allowed the fan to start and the compressor started to cool the refrigerator. But obviously I can't use the refrig that way. Would a faulty thermistor prohibit AC from reaching the compressor and fan? I'm hoping it's not the control board. Any suggestions would be greatly appreciated. Barry
reggaemoose - Réponse
Great question! I'm going to call in @billg66 (Bill G) as iFixit's appliance pro. If you're able to share your make/model, or find a circuit schematic, your questions about the electrical pathway could be more easily solved. Good luck.
nicO -
Hi Barry, your model number would be a huge help as then I can get service manuals. I'd be cautious about using a 3 in 1. Especially if your fridge was designed to use just a start relay. I think there could be an issue with the thermistor, or possibly the control board, given that the compressor ran when jumped. 3 in 1s are great to squeeze out a little more life from a compressor, but this may not be that case.
Bill Gilbert -
I have a Whirlpool Top Freezer Refrig Model: WRT311FZDW01 and I replaced the Control Board and the Freezer Thermistor to fix excessive wet in the Refrig section (condensation). It is now dry and cooling the Freezer well and working the Freezer as designed. However, the Refrig section does not seem to be Cold ENOUGH. I suspect the Thermistor for the Refrig (I assume there are 2 thermistors). But, I cannot find the location of the Lower/Refrig Thermistor. Is ther 2? and wher would I find the 2nd Thermistor (I suspect in the Temp Control Housing ??).
Fiddly Bits - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 42
30 derniers jours : 159
Total : 5,491
