Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Withings Smart Body Analyzer LCD Screen Replacement
Ce dont vous avez besoin
    1. Withings Smart Body Analyzer LCD Screen Replacement, Withings Smart Body Analyzer Disassembly: étape 1, image 1 de 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Demander à FixBot
      Ajouter un commentaire
    2. Withings Smart Body Analyzer LCD Screen Replacement: étape 2, image 1 de 3 Withings Smart Body Analyzer LCD Screen Replacement: étape 2, image 2 de 3 Withings Smart Body Analyzer LCD Screen Replacement: étape 2, image 3 de 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Demander à FixBot
    3. Withings Smart Body Analyzer LCD Screen Replacement: étape 3, image 1 de 2 Withings Smart Body Analyzer LCD Screen Replacement: étape 3, image 2 de 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Demander à FixBot
    1. Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: étape 4, image 1 de 2 Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: étape 4, image 2 de 2
      • After the tempered glass panel has been removed, the screen can be accessed and is connected by a ribbon cable via the circuit board.
      • Gently remove the wire from the circuit board by gently pushing downward and away from the screen, on the metal tab that connects the wire to the circuit board.
      Demander à FixBot
    2. Withings Smart Body Analyzer LCD Screen Replacement: étape 5, image 1 de 1
      • Using the Phillips screwdriver head, unscrew the two screws that hold the screen in place.
      Demander à FixBot
    3. Withings Smart Body Analyzer LCD Screen Replacement: étape 6, image 1 de 1
      • The screen should be free from all constraints and all that is left is to carefully lift and remove the screen.
      Demander à FixBot
2 autres ont terminé cette réparation.
omar shehadi
Membre depuis le 03/22/17
219 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 membres
5 tutoriels rédigés
2 commentaires de tutoriel
Where can I get a new LCD screen for replacement?
Putra Jaya - Réponse Partager
problem is that I didn´t find new LCD on the internet :-(
krwell - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 43
Total : 4,185
