Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Withings Smart Body Analyzer Pressure Sensor Replacement
Ce dont vous avez besoin
  1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: étape 1, image 1 de 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
    Demander à FixBot
    Ajouter un commentaire
  2. Withings Smart Body Analyzer Pressure Sensor Replacement: étape 2, image 1 de 3 Withings Smart Body Analyzer Pressure Sensor Replacement: étape 2, image 2 de 3 Withings Smart Body Analyzer Pressure Sensor Replacement: étape 2, image 3 de 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
    Demander à FixBot
  3. Withings Smart Body Analyzer Pressure Sensor Replacement: étape 3, image 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: étape 3, image 2 de 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
    Demander à FixBot
  4. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: étape 4, image 1 de 1
    • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
    • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
    Demander à FixBot
  5. Withings Smart Body Analyzer Pressure Sensor Replacement: étape 5, image 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: étape 5, image 2 de 2
    • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
    Demander à FixBot
  6. Withings Smart Body Analyzer Pressure Sensor Replacement: étape 6, image 1 de 2 Withings Smart Body Analyzer Pressure Sensor Replacement: étape 6, image 2 de 2
    • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
    Demander à FixBot
Ashley Dauphinee
Membre depuis le 03/22/17
323 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 membres
5 tutoriels rédigés
3 commentaires de tutoriel
Where do I get those replacements?
karina - Réponse Partager
where can I buy pressure sensors?
Andrey Kolesov - Réponse Partager
The issue is not the pressure sensor, but a weak area within the foot.
Having taken my scales apart to repair them I found the the foot (pictured within the plastic ring above) has a metal disc in it, that is supported by a few weak plastic ribs that easily damage. I filled them in with Araldyte to create a firm level surface and all is good again.
As a design engineer who fault-finds all day, I would say this is either poor design (an oversight), or brilliant salesmanship (a weak point that allows Withings to sell more scales). Which is true? Only they know.
FlashingIcon - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 53
Total : 4,753
