Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox Duke Controller Potentiometer Replacement
Ce dont vous avez besoin
  1. Xbox Duke Controller Potentiometer Replacement, Face Plate: étape 1, image 1 de 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: étape 1, image 2 de 3 Xbox Duke Controller Potentiometer Replacement, Face Plate: étape 1, image 3 de 3
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox Duke Controller Potentiometer Replacement: étape 2, image 1 de 3 Xbox Duke Controller Potentiometer Replacement: étape 2, image 2 de 3 Xbox Duke Controller Potentiometer Replacement: étape 2, image 3 de 3
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
    Demander à FixBot
  3. Xbox Duke Controller Potentiometer Replacement, Potentiometer: étape 3, image 1 de 2 Xbox Duke Controller Potentiometer Replacement, Potentiometer: étape 3, image 2 de 2
    • Remove the stick caps from the potentiometers.
    Demander à FixBot
  4. Xbox Duke Controller Potentiometer Replacement: étape 4, image 1 de 2 Xbox Duke Controller Potentiometer Replacement: étape 4, image 2 de 2
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
    Demander à FixBot
  5. Xbox Duke Controller Potentiometer Replacement: étape 5, image 1 de 2 Xbox Duke Controller Potentiometer Replacement: étape 5, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
    Demander à FixBot
  6. Xbox Duke Controller Potentiometer Replacement: étape 6, image 1 de 2 Xbox Duke Controller Potentiometer Replacement: étape 6, image 2 de 2
    • Remove the motherboard from the bottom half of the controller.
    Demander à FixBot
  7. Xbox Duke Controller Potentiometer Replacement: étape 7, image 1 de 3 Xbox Duke Controller Potentiometer Replacement: étape 7, image 2 de 3 Xbox Duke Controller Potentiometer Replacement: étape 7, image 3 de 3
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
    Demander à FixBot
  8. Xbox Duke Controller Potentiometer Replacement: étape 8, image 1 de 1
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
    Demander à FixBot
Anthony Casino
Membre depuis le 02/15/25
642 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025 Membre de l'équipe UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025
UMASSD-GULBRANDSEN-S25S1G1
1 membre
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 66
Total : 842
