Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox One Elite Controller (Model 1698) Disassembly
Ce dont vous avez besoin
  1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: étape 1, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: étape 1, image 2 de 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: étape 2, image 1 de 1
    • Remove the 5 Torx Security Bit (TR9) screws.
    Demander à FixBot
  3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: étape 3, image 1 de 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: étape 3, image 2 de 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: étape 3, image 3 de 3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
    Demander à FixBot
  4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: étape 4, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: étape 4, image 2 de 2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
    Demander à FixBot
  5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: étape 5, image 1 de 1
    • Remove the 2 Torx (T6) screws.
    Demander à FixBot
  6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: étape 6, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: étape 6, image 2 de 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
    Demander à FixBot
  7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: étape 7, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: étape 7, image 2 de 2
    • Pull up from the "top" side of the controller on the daughterboard.
    Demander à FixBot
  8. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: étape 8, image 1 de 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: étape 8, image 2 de 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: étape 8, image 3 de 3
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
    Demander à FixBot
  9. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: étape 9, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: étape 9, image 2 de 2
    • Unscrew the 6 Torx (T6) screws.
    Demander à FixBot
  10. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: étape 10, image 1 de 2 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: étape 10, image 2 de 2
    • Now you can remove the buttons themselves.
    Demander à FixBot
45 autres ont terminé cette réparation.
EasyAsABC123
Membre depuis le 01/22/10
2 557 Réputation
5 tutoriels rédigés
14 commentaires de tutoriel
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - Réponse Partager
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph - Réponse Partager
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - Réponse Partager
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - Réponse Partager
Thanks for the info
EasyAsABC123 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 67
30 derniers jours : 309
Total : 105,153
