Aller au contenu principal
Xbox Series S Motherboard Replacement
Ce dont vous avez besoin
  1. Xbox Series S Motherboard Replacement, Peel off the sticker coverings: étape 1, image 1 de 3 Xbox Series S Motherboard Replacement, Peel off the sticker coverings: étape 1, image 2 de 3 Xbox Series S Motherboard Replacement, Peel off the sticker coverings: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Motherboard Replacement, Remove the back panel screws: étape 2, image 1 de 1
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Motherboard Replacement, Remove the bottom panel: étape 3, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the bottom panel: étape 3, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the bottom panel: étape 3, image 3 de 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Motherboard Replacement, Remove the plastic case screws: étape 4, image 1 de 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Motherboard Replacement, Remove the plastic case: étape 5, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the plastic case: étape 5, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the plastic case: étape 5, image 3 de 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Motherboard Replacement: étape 6, image 1 de 3 Xbox Series S Motherboard Replacement: étape 6, image 2 de 3 Xbox Series S Motherboard Replacement: étape 6, image 3 de 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Motherboard Replacement, Remove the Bluetooth board: étape 7, image 1 de 1
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
  8. Xbox Series S Motherboard Replacement: étape 8, image 1 de 3 Xbox Series S Motherboard Replacement: étape 8, image 2 de 3 Xbox Series S Motherboard Replacement: étape 8, image 3 de 3
    • Use a spudger to pry and loosen the Bluetooth board.
    • Do not pry from the bottom or sides of the Bluetooth board as it may bend the connector.
    • Pull the Bluetooth board straight out to disconnect it from the chassis.
  9. Xbox Series S Motherboard Replacement, Remove the power button board: étape 9, image 1 de 1
    • Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
  10. Xbox Series S Motherboard Replacement: étape 10, image 1 de 3 Xbox Series S Motherboard Replacement: étape 10, image 2 de 3 Xbox Series S Motherboard Replacement: étape 10, image 3 de 3
    • Use a spudger to pry and loosen the power button board.
    • Do not pry from the bottom of the power button board as it may bend the connector.
    • Pull the power button board straight out to disconnect it from the chassis.
  11. Xbox Series S Motherboard Replacement, Remove the Wi-Fi board: étape 11, image 1 de 1
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Wi-Fi board to the short edge of the chassis.
  12. Xbox Series S Motherboard Replacement: étape 12, image 1 de 3 Xbox Series S Motherboard Replacement: étape 12, image 2 de 3 Xbox Series S Motherboard Replacement: étape 12, image 3 de 3
    • Use a spudger to pry and loosen the Wi-Fi board.
    • Do not pry from the bottom or sides of the Wi-Fi board as it may bend the connector.
    • Pull the Wi-Fi board straight out to disconnect it from the chassis.
  13. Xbox Series S Motherboard Replacement, Remove the power supply screws: étape 13, image 1 de 1
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
  14. Xbox Series S Motherboard Replacement, Remove the upper chassis: étape 14, image 1 de 2 Xbox Series S Motherboard Replacement, Remove the upper chassis: étape 14, image 2 de 2
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  15. Xbox Series S Motherboard Replacement, Remove the power supply: étape 15, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the power supply: étape 15, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the power supply: étape 15, image 3 de 3
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
  16. Xbox Series S Motherboard Replacement, Remove the fan screws: étape 16, image 1 de 1
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
  17. Xbox Series S Motherboard Replacement, Disconnect the fan: étape 17, image 1 de 2 Xbox Series S Motherboard Replacement, Disconnect the fan: étape 17, image 2 de 2
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
  18. Xbox Series S Motherboard Replacement, Remove the fan: étape 18, image 1 de 2 Xbox Series S Motherboard Replacement, Remove the fan: étape 18, image 2 de 2
    • Lift the fan straight up to remove it from the motherboard.
  19. Attention : les étapes 19 à 21 sont issues d'un tutoriel marqué comme étant en cours.
    Xbox Series S Motherboard Replacement, Remove the motherboard screws: étape 19, image 1 de 1
    • Use a T8 Torx driver to remove the four 9.4 mm-long screws securing the motherboard to the chassis.
  20. Xbox Series S Motherboard Replacement, Remove the locking clip: étape 20, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the locking clip: étape 20, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the locking clip: étape 20, image 3 de 3
    • Insert a spudger into the locking clip located on the front-left corner of the chassis.
    • This will open up the clip to make it easier to remove.
    • Lift straight up to remove the clip.
  21. Xbox Series S Motherboard Replacement, Remove the motherboard: étape 21, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the motherboard: étape 21, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the motherboard: étape 21, image 3 de 3
    • Grasp the heat sink with your fingers and lift up the front of the motherboard up above the edge of the chassis.
    • Pull the motherboard towards the front of the chassis to remove it.
  22. Xbox Series S Motherboard Replacement, Remove the SSD card: étape 22, image 1 de 1
    • Use a T8 Torx driver to remove the 5.1 mm-long screw securing the SSD card to the motherboard.
  23. Xbox Series S Motherboard Replacement: étape 23, image 1 de 3 Xbox Series S Motherboard Replacement: étape 23, image 2 de 3 Xbox Series S Motherboard Replacement: étape 23, image 3 de 3
    • Pull the SSD card straight out and remove it from the motherboard.
  24. Xbox Series S Motherboard Replacement, Remove the x-clamp: étape 24, image 1 de 3 Xbox Series S Motherboard Replacement, Remove the x-clamp: étape 24, image 2 de 3 Xbox Series S Motherboard Replacement, Remove the x-clamp: étape 24, image 3 de 3
    Flathead 1.5 mm Screwdriver
    $5.49
    • Insert a 1.5 mm flathead screwdriver from the top between the heat sink pin and the x-clamp.
    • Pry the x-clamp out and away from the heat sink pin to loosen the x-clamp.
    • Do not attempt to completely release the x-clamp with this technique.
  25. Xbox Series S Motherboard Replacement: étape 25, image 1 de 3 Xbox Series S Motherboard Replacement: étape 25, image 2 de 3 Xbox Series S Motherboard Replacement: étape 25, image 3 de 3
    • With the head parallel to the motherboard, insert a flathead screwdriver from the side between the heat sink pin and the x-clamp hook.
    • Twist the flathead screwdriver clockwise to pry the bottom edge of the x-clamp out of the groove in the heat sink pin.
    • If you have trouble, try using a larger flathead screwdriver.
    • As you twist, the x-clamp should pop off the heat sink pin. If not, try repeating the previous step before attempting this one again.
  26. Xbox Series S Motherboard Replacement: étape 26, image 1 de 1
    • Continue to use the same technique described in the previous two steps on all of the heat sink pins until the x-clamp is disconnected.
  27. Xbox Series S Motherboard Replacement: étape 27, image 1 de 2 Xbox Series S Motherboard Replacement: étape 27, image 2 de 2
    • Remove the x-clamp.
    • When reattaching the x-clamp, you should be able to attach two to three sides just by pressing down the x-clamp hooks onto the heat sink pins. Then use the flathead screwdriver to pry the x-clamp hooks over the heat sink pins.
  28. Xbox Series S Motherboard Replacement, Remove the heat sink: étape 28, image 1 de 2 Xbox Series S Motherboard Replacement, Remove the heat sink: étape 28, image 2 de 2
    • Flip the motherboard over.
    • Take care when flipping the motherboard over because the heat sink may fall out.
    • Lift the heat sink straight up to remove it from the motherboard.
    • One of the most common symptoms of consoles overheating is a clogged heat sink. Take time to remove the dust and debris between the heat sink fins.
  29. Xbox Series S Motherboard Replacement: étape 29, image 1 de 2 Xbox Series S Motherboard Replacement: étape 29, image 2 de 2
    • Only the motherboard remains.
    • Follow this guide for more specifics on how to reapply thermal paste to the processor and shield plate.
    • Since normal thermal paste isn’t designed to bridge the large gaps between the shield plate and heat sink, use K5 Pro viscous thermal paste to replace the thicker, teal putty. You will, however, need normal replacement thermal paste for the APU.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
16 autres ont terminé cette réparation.
Robert Boyd
Membre depuis le 02/01/21
29 430 Réputation
94 tutoriels rédigés
9Commentaires sur le guide
for some reason to me it seems like the apu is just an am4 cpu stuck on to the motherboard, could you guys do some measuring to find out?
Gage - Réponse
Where can I get a new motherboard and new replacement parts ? Please help
Israel Velez - Réponse
Exactly, where can anyone get a motherboard?
I mean, dismounting it is the easy part!
JoeBlog - Réponse
I’m looking for a replacement motherboard. Has anyone figured out where to get one?
NathanK - Réponse
Among us work great
Mathew - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 51
7 derniers jours : 313
30 derniers jours : 1,487
Total : 45,335
