Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xiaomi Mi Note Screen Replacement
Ce dont vous avez besoin
    1. Xiaomi Mi Note Screen Replacement, Dual SIM SD Card: étape 1, image 1 de 1
      • Locate the hole for the Dual SIM SD card on the left side of the phone.
      Demander à FixBot
      Ajouter un commentaire
    2. Xiaomi Mi Note Screen Replacement: étape 2, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 2, image 2 de 2
      • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
      Demander à FixBot
    1. Xiaomi Mi Note Screen Replacement, Battery: étape 3, image 1 de 2 Xiaomi Mi Note Screen Replacement, Battery: étape 3, image 2 de 2
      • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
      Demander à FixBot
    2. Xiaomi Mi Note Screen Replacement: étape 4, image 1 de 3 Xiaomi Mi Note Screen Replacement: étape 4, image 2 de 3 Xiaomi Mi Note Screen Replacement: étape 4, image 3 de 3
      • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
      • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
      • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
      • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
      Demander à FixBot
    3. Xiaomi Mi Note Screen Replacement: étape 5, image 1 de 1
      • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
      Demander à FixBot
    4. Xiaomi Mi Note Screen Replacement: étape 6, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 6, image 2 de 2
      • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
      • Glue will be holding down the backside of the battery.
      Demander à FixBot
    1. Xiaomi Mi Note Screen Replacement, Screen: étape 7, image 1 de 3 Xiaomi Mi Note Screen Replacement, Screen: étape 7, image 2 de 3 Xiaomi Mi Note Screen Replacement, Screen: étape 7, image 3 de 3
      • Use a spudger to detach the ribbons connected to the motherboard using an upward prying motion.
      Demander à FixBot
    2. Xiaomi Mi Note Screen Replacement: étape 8, image 1 de 3 Xiaomi Mi Note Screen Replacement: étape 8, image 2 de 3 Xiaomi Mi Note Screen Replacement: étape 8, image 3 de 3
      Outil utilisé dans cette étape :
      • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
      • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
      • When detaching the ribbon on the left use minimal force to prevent damage.
      Demander à FixBot
    3. Xiaomi Mi Note Screen Replacement: étape 9, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 9, image 2 de 2
      • Use a tweezer to lift and remove the motherboard from the frame.
      • Be sure that the Dual SIM card and tray has been removed.
      Demander à FixBot
    4. Xiaomi Mi Note Screen Replacement: étape 10, image 1 de 1
      • Peel back the ribbon that is adhered to the metal surface as shown.
      Demander à FixBot
    5. Xiaomi Mi Note Screen Replacement: étape 11, image 1 de 3 Xiaomi Mi Note Screen Replacement: étape 11, image 2 de 3 Xiaomi Mi Note Screen Replacement: étape 11, image 3 de 3
      • The dock connector is firmly adhered to the frame below it. To prevent damage to the phone use minimal force when removing.
      • Using tweezers slowly start prying upwards at the locations shown in the images. After carefully prying around the edges of the dock connector, it can now lifted upwards out of the frame.
      Demander à FixBot
    6. Xiaomi Mi Note Screen Replacement: étape 12, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 12, image 2 de 2
      • Using a spudger detach the top two ribbons that connect the screen to the touch sensor and motherboard using an upwards prying motion.
      Demander à FixBot
    7. Xiaomi Mi Note Screen Replacement: étape 13, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 13, image 2 de 2
      • Using tweezers lift the two remaining ribbons from the bottom frame by grasping the ribbons at any point and lifting towards the bottom of the frame.
      • The ribbons should now be able to freely slide through the respective slits once the screen is lose enough to pull away from the frame for later.
      Demander à FixBot
    8. Xiaomi Mi Note Screen Replacement: étape 14, image 1 de 2 Xiaomi Mi Note Screen Replacement: étape 14, image 2 de 2
      • Peel back the ribbon attached to the back metal frame.
      • Use your spudger at any point to get underneath the metal frame. Slide the spudger around the sides of the metal to free it from the frame.
      • Small amounts of adhesive are holding the metal frame in place.
      Demander à FixBot
    9. Xiaomi Mi Note Screen Replacement: étape 15, image 1 de 3 Xiaomi Mi Note Screen Replacement: étape 15, image 2 de 3 Xiaomi Mi Note Screen Replacement: étape 15, image 3 de 3
      • Apply considerable force to the back corners using your spudger to help relieve it of the adhesive as shown.
      • Once you have freed the screen from a portion of the adhesive, wedge your spudger around the front edge to work around the edges of the screen and frame in order to fully remove it from the frame.
      • Be aware that the glass screen will break during this process. Be careful not to cut yourself while preforming this step.
      Demander à FixBot
21 autres ont terminé cette réparation.
Mark Sears
Membre depuis le 08/27/15
1 265 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-6, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 membres
18 tutoriels rédigés
3 commentaires de tutoriel
Looks like there is no procedure to explain how to put a new screen on there.
Lee - Réponse Partager
You don't need a Screen now. You have now successfully screwed your phone to a whopping 100%.
ranjit - Réponse Partager
Hello, I have unmounted my mi note pro to change the battery. I successfully changed it but now my phone's touch screen does not work anymore. The screen displays but the touch function doesn't work. Can someone help me identify the part I might have damaged or disconnected accidentally?
aimane786 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 18
30 derniers jours : 63
Total : 16,781
