Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xiaomi Redmi Note Front-Facing Camera Replacement
Ce dont vous avez besoin
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: étape 1, image 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    Demander à FixBot
    Ajouter un commentaire
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: étape 2, image 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: étape 2, image 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    Demander à FixBot
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: étape 3, image 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: étape 3, image 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    Demander à FixBot
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: étape 4, image 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: étape 4, image 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    Demander à FixBot
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: étape 5, image 1 de 2 Xiaomi Redmi Note Front-Facing Camera Replacement: étape 5, image 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    Demander à FixBot
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: étape 6, image 1 de 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: étape 6, image 2 de 3 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
    Demander à FixBot
2 autres ont terminé cette réparation.
Caitlin Settles
Membre depuis le 04/26/17
789 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 membres
24 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 44
Total : 2,031
