Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xiaomi Redmi Note Rear Camera Replacement
Ce dont vous avez besoin
  1. Xiaomi Redmi Note Rear Camera Replacement, Battery: étape 1, image 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    Demander à FixBot
    Ajouter un commentaire
  2. Xiaomi Redmi Note Rear Camera Replacement: étape 2, image 1 de 2 Xiaomi Redmi Note Rear Camera Replacement: étape 2, image 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    Demander à FixBot
  3. Xiaomi Redmi Note Rear Camera Replacement: étape 3, image 1 de 2 Xiaomi Redmi Note Rear Camera Replacement: étape 3, image 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    Demander à FixBot
  4. Xiaomi Redmi Note Rear Camera Replacement, Midframe: étape 4, image 1 de 2 Xiaomi Redmi Note Rear Camera Replacement, Midframe: étape 4, image 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    Demander à FixBot
  5. Xiaomi Redmi Note Rear Camera Replacement: étape 5, image 1 de 2 Xiaomi Redmi Note Rear Camera Replacement: étape 5, image 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    Demander à FixBot
  6. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: étape 6, image 1 de 2 Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: étape 6, image 2 de 2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
    Demander à FixBot
4 autres ont terminé cette réparation.
AJ Beers
Membre depuis le 04/26/17
213 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 membres
24 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 49
Total : 4,263
