Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xiaomi Redmi Note Screen Replacement
Ce dont vous avez besoin
  1. Xiaomi Redmi Note Screen Replacement, Battery: étape 1, image 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    Demander à FixBot
    Ajouter un commentaire
  2. Xiaomi Redmi Note Screen Replacement: étape 2, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 2, image 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    Demander à FixBot
  3. Xiaomi Redmi Note Screen Replacement: étape 3, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 3, image 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    Demander à FixBot
  4. Xiaomi Redmi Note Screen Replacement, Midframe: étape 4, image 1 de 2 Xiaomi Redmi Note Screen Replacement, Midframe: étape 4, image 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    Demander à FixBot
  5. Xiaomi Redmi Note Screen Replacement: étape 5, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 5, image 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    Demander à FixBot
  6. Xiaomi Redmi Note Screen Replacement, Charging Port: étape 6, image 1 de 2 Xiaomi Redmi Note Screen Replacement, Charging Port: étape 6, image 2 de 2
    • Locate the charging port panel at the bottom of the device.
    • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
    Demander à FixBot
  7. Xiaomi Redmi Note Screen Replacement: étape 7, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 7, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • Locate the antenna cable at the top right corner of the charging port.
    • Lift the antenna cable off of the panel with tweezers.
    Demander à FixBot
  8. Xiaomi Redmi Note Screen Replacement: étape 8, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 8, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 8, image 3 de 3
    • Flip the panel to its back side, but do not fully lift it off of the phone yet.
    • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
    Demander à FixBot
  9. Xiaomi Redmi Note Screen Replacement: étape 9, image 1 de 1
    • Lift the charging port up to remove it from the frame.
    Demander à FixBot
  10. Xiaomi Redmi Note Screen Replacement, Front-Facing Camera: étape 10, image 1 de 3 Xiaomi Redmi Note Screen Replacement, Front-Facing Camera: étape 10, image 2 de 3 Xiaomi Redmi Note Screen Replacement, Front-Facing Camera: étape 10, image 3 de 3
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
    Demander à FixBot
  11. Xiaomi Redmi Note Screen Replacement, Rear Camera: étape 11, image 1 de 2 Xiaomi Redmi Note Screen Replacement, Rear Camera: étape 11, image 2 de 2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
    Demander à FixBot
  12. Xiaomi Redmi Note Screen Replacement, Motherboard: étape 12, image 1 de 1
    • Locate the three ZIF connectors on the motherboard.
    Demander à FixBot
  13. Xiaomi Redmi Note Screen Replacement: étape 13, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 13, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 13, image 3 de 3
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
    Demander à FixBot
  14. Xiaomi Redmi Note Screen Replacement: étape 14, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 14, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 14, image 3 de 3
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
    Demander à FixBot
  15. Xiaomi Redmi Note Screen Replacement: étape 15, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 15, image 2 de 2
    • Remove the two 2.9mm Philips #00 screws.
    Demander à FixBot
  16. Xiaomi Redmi Note Screen Replacement: étape 16, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 16, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 16, image 3 de 3
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
    Demander à FixBot
  17. Xiaomi Redmi Note Screen Replacement: étape 17, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 17, image 2 de 2
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
    Demander à FixBot
  18. Xiaomi Redmi Note Screen Replacement: étape 18, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 18, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 18, image 3 de 3
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
    Demander à FixBot
  19. Xiaomi Redmi Note Screen Replacement, Screen: étape 19, image 1 de 3 Xiaomi Redmi Note Screen Replacement, Screen: étape 19, image 2 de 3 Xiaomi Redmi Note Screen Replacement, Screen: étape 19, image 3 de 3
    • Use tweezers to pull out the rubber proximity sensor from the top left of the frame
    Demander à FixBot
  20. Xiaomi Redmi Note Screen Replacement: étape 20, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 20, image 2 de 2
    • Use tweezers to peel off the screen ribbon cable from the frame.
    • Do not be afraid to use a bit of force as the ribbon cable is glued onto the frame.
    Demander à FixBot
  21. Xiaomi Redmi Note Screen Replacement: étape 21, image 1 de 1
    • Heat up the surface of the screen using a heat gun or hair dryer for 20 minutes.
    • It is better to put the heat gun at a lower temperature and heat the screen up for a longer time to avoid damaging the frame.
    Demander à FixBot
  22. Xiaomi Redmi Note Screen Replacement: étape 22, image 1 de 1
    • Slightly flex the frame to insert a plastic prying tool between the screen and the frame.
    Demander à FixBot
  23. Xiaomi Redmi Note Screen Replacement: étape 23, image 1 de 2 Xiaomi Redmi Note Screen Replacement: étape 23, image 2 de 2
    • Run the plastic opening tool around the seam between the screen and the frame until an opening can be seen.
    Demander à FixBot
  24. Xiaomi Redmi Note Screen Replacement: étape 24, image 1 de 3 Xiaomi Redmi Note Screen Replacement: étape 24, image 2 de 3 Xiaomi Redmi Note Screen Replacement: étape 24, image 3 de 3
    • Place a finger into the opening and continue peeling away the screen from the frame.
    • If the screen is cracked, avoid touching it. Instead, peel up from the metal underside of the screen to avoid getting cut.
    • Watch out for the ribbon cable that is fed through an opening in the top right corner of the frame. The screen will not come out unless the cable fits through the opening.
    Demander à FixBot
6 autres ont terminé cette réparation.
Zongyi Li
Membre depuis le 04/26/17
1 635 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 membres
16 tutoriels rédigés
1 commentaire de tutoriel
I followed this guide which helped me replace my screen for my Xiaomi Redmi Note 3. The Redmi note 3 is very similar and and the screen is attached in almost an identical manner.
Alexander - Réponse Partager
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 21
30 derniers jours : 76
Total : 16,390
