Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Zerodate T26 RGB LED Replacement
Ce dont vous avez besoin
    1. Zerodate T26 RGB LED Replacement, Scroll Wheel: étape 1, image 1 de 2 Zerodate T26 RGB LED Replacement, Scroll Wheel: étape 1, image 2 de 2
      • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
      Demander à FixBot
      Ajouter un commentaire
    2. Zerodate T26 RGB LED Replacement: étape 2, image 1 de 2 Zerodate T26 RGB LED Replacement: étape 2, image 2 de 2
      Outil utilisé dans cette étape :
      • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
      • Adhesive pads are located on the bottom of the mouse.
      Demander à FixBot
    3. Zerodate T26 RGB LED Replacement: étape 3, image 1 de 2 Zerodate T26 RGB LED Replacement: étape 3, image 2 de 2
      • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
      Demander à FixBot
    4. Zerodate T26 RGB LED Replacement: étape 4, image 1 de 2 Zerodate T26 RGB LED Replacement: étape 4, image 2 de 2
      • Carefully pull the middle shell apart from the bottom plate.
      • The circuit board should then be visible and attached to the bottom plate.
      Demander à FixBot
    5. Zerodate T26 RGB LED Replacement: étape 5, image 1 de 2 Zerodate T26 RGB LED Replacement: étape 5, image 2 de 2
      • Remove the scroll wheel by pushing it to the right and pulling up.
      Demander à FixBot
    1. Zerodate T26 RGB LED Replacement, RGB LED: étape 6, image 1 de 3 Zerodate T26 RGB LED Replacement, RGB LED: étape 6, image 2 de 3 Zerodate T26 RGB LED Replacement, RGB LED: étape 6, image 3 de 3
      • Disconnect the battery from the circuit board.
      • Use the precision tweezers to remove the tape from the circuit board.
      • Carefully pull apart the circuit board from the bottom shell.
      Demander à FixBot
    2. Zerodate T26 RGB LED Replacement: étape 7, image 1 de 1
      • Desolder the LEDs from the circuit board and solder on the new LEDs following the soldering guide.
      • Please be sure to review safety guidelines and guided steps on soldering/desoldering before attempting remove of LEDs
      Demander à FixBot
Janice Rullan
Membre depuis le 03/13/23
662 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G3
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 20
Total : 391
