Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Zoom H1 Handy Recorder Line-In Port Replacement
Ce dont vous avez besoin
    1. Zoom H1 Handy Recorder Line-In Port Replacement, Line-In Port: étape 1, image 1 de 1
      • Flip device over so the display is facing down.
      Demander à FixBot
      Ajouter un commentaire
    2. Zoom H1 Handy Recorder Line-In Port Replacement: étape 2, image 1 de 1
      • Remove the battery cover by pressing down on battery cover and sliding it to the right.
      Demander à FixBot
    3. Zoom H1 Handy Recorder Line-In Port Replacement: étape 3, image 1 de 1
      • Remove the two 10 mm Phillips #00 screws located below the microphones on the back cover.
      Demander à FixBot
    4. Zoom H1 Handy Recorder Line-In Port Replacement: étape 4, image 1 de 1
      • Remove the back cover (using a plastic removal tool around the edges if needed).
      Demander à FixBot
    5. Zoom H1 Handy Recorder Line-In Port Replacement: étape 5, image 1 de 1
      • De-solder and remove the heat shield.
      • Be careful while removing this shield, since the copper sheet is very easy to rip.
      Demander à FixBot
    6. Zoom H1 Handy Recorder Line-In Port Replacement: étape 6, image 1 de 1
      • De-solder the line in port from its soldering points.
      • These points are located beneath the black shielding on the left side of the blue circuit board.
      Demander à FixBot
    7. Zoom H1 Handy Recorder Line-In Port Replacement: étape 7, image 1 de 1
      • Replace Line-in port and re-solder at points specified in Step 6.
      Demander à FixBot
    8. Zoom H1 Handy Recorder Line-In Port Replacement: étape 8, image 1 de 1
      • Reattach and re-solder the heat shielding back into place.
      • Again, be careful when soldering as it is very easy to melt through the heat shield and copper sheet beneath.
      Demander à FixBot
Alex
Membre depuis le 10/28/13
809 Réputation
5 tutoriels rédigés
3 commentaires de tutoriel
Do you know what and where I can get the replacement part at all…?
phily2k1clegg - Réponse Partager
There are actually three fixing screws which must be unscrewed before the back can be removed, the third one is under the serial number label.
To actually change the audio socket the top PCB with the sockets has to be removed from the unit, it has the microphones soldered to the top edge and the speaker soldered to the bottom with short, delicate wires, it can be pulled out to one side without de-soldering anything by pulling the right (looking from the back) microphone off it’s supporting lug.
The top board is connected to the bottom board by a miniature plug and socket attached to both boards which can just be pulled apart.
sdsl - Réponse Partager
Hello. My zoom h1 had fallen to the carpet. And the usb dc 5v usb socket had started to move and it is not doing its job. It is not working when i want to use the electric cable. Is fixing possible myself or another person?
cankarkin - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 51
Total : 5,304
