Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iBook G3 12" RAM Replacement
Ce dont vous avez besoin
  1. iBook G3 12" RAM Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. iBook G3 12" RAM Replacement, Keyboard: étape 2, image 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Demander à FixBot
  3. iBook G3 12" RAM Replacement: étape 3, image 1 de 1
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    Demander à FixBot
  4. iBook G3 12" RAM Replacement: étape 4, image 1 de 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    Demander à FixBot
  5. iBook G3 12" RAM Replacement: étape 5, image 1 de 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    Demander à FixBot
  6. iBook G3 12" RAM Replacement: étape 6, image 1 de 1
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    Demander à FixBot
  7. iBook G3 12" RAM Replacement: étape 7, image 1 de 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Demander à FixBot
  8. iBook G3 12" RAM Replacement: étape 8, image 1 de 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Demander à FixBot
  9. iBook G3 12" RAM Replacement, RAM: étape 9, image 1 de 1
    • Your laptop should look approximately like this.
    Demander à FixBot
  10. iBook G3 12" RAM Replacement: étape 10, image 1 de 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
    Demander à FixBot
47 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 56
Total : 34,692
