Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iBook G3 Clamshell RAM Replacement
Ce dont vous avez besoin
    1. iBook G3 Clamshell RAM Replacement, Battery: étape 1, image 1 de 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Demander à FixBot
      Ajouter un commentaire
    1. iBook G3 Clamshell RAM Replacement, Airport Card: étape 2, image 1 de 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Demander à FixBot
    2. iBook G3 Clamshell RAM Replacement: étape 3, image 1 de 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Demander à FixBot
    3. iBook G3 Clamshell RAM Replacement: étape 4, image 1 de 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Demander à FixBot
    1. iBook G3 Clamshell RAM Replacement, Keyboard: étape 5, image 1 de 1
      • Remove the two Phillips screws that secure the RAM shield.
      Demander à FixBot
    2. iBook G3 Clamshell RAM Replacement: étape 6, image 1 de 1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      Demander à FixBot
    3. iBook G3 Clamshell RAM Replacement: étape 7, image 1 de 1
      • Pull up the keyboard connector cable by its clear plastic loop.
      Demander à FixBot
    1. iBook G3 Clamshell RAM Replacement, RAM: étape 8, image 1 de 1
      • Your laptop should look approximately like this.
      Demander à FixBot
    2. iBook G3 Clamshell RAM Replacement: étape 9, image 1 de 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      Demander à FixBot
20 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
635 tutoriels rédigés
1 commentaire de tutoriel
I love that iFixit will sell you a quarter ($0.25) for $2.99 plus tax and shipping, another $3.29 shipping (totally reasonable), and sales tax for my location - the total is $6.59. I wish I could sell quarters for $6.59. 🤣
UnCoopervised - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 25
30 derniers jours : 91
Total : 24,668
