Introduction
If your iHome iAVS16 isn’t producing the correct display on the screen or is not working at all, this guide will show you step by step how to disassemble the iHome iAVS16 to access and replace the LCD display. If LCD display still does not work after replacement then start looking else where for issues.
Ce dont vous avez besoin
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
Further remove the front casing off from the device manually with your hands.
