Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iHome iH8BR Buttons Replacement
Ce dont vous avez besoin
    1. iHome iH8BR Buttons Replacement, Lower Case: étape 1, image 1 de 3 iHome iH8BR Buttons Replacement, Lower Case: étape 1, image 2 de 3 iHome iH8BR Buttons Replacement, Lower Case: étape 1, image 3 de 3
      • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
      • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
      • Remove the battery cover and the batteries.
      Demander à FixBot
      Ajouter un commentaire
    2. iHome iH8BR Buttons Replacement: étape 2, image 1 de 2 iHome iH8BR Buttons Replacement: étape 2, image 2 de 2
      • Slide a spudger under the two front rubber pads to expose two hidden screws.
      Demander à FixBot
    3. iHome iH8BR Buttons Replacement: étape 3, image 1 de 1
      • Remove the following eight screws:
      • Four 15.1 mm Phillips #2 screws near the front of the device.
      • Four 12.7 mm Phillips #2 screws near the back of the device.
      • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
      Demander à FixBot
    4. iHome iH8BR Buttons Replacement: étape 4, image 1 de 2 iHome iH8BR Buttons Replacement: étape 4, image 2 de 2
      Outil utilisé dans cette étape :
      • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
      • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
      • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
      • The lower case can now be completely removed from the device!
      Demander à FixBot
    1. iHome iH8BR Buttons Replacement, Motherboard Assembly: étape 5, image 1 de 2 iHome iH8BR Buttons Replacement, Motherboard Assembly: étape 5, image 2 de 2
      • Remove the four screws attaching the top of the case to the motherboard:
      • Two 9.5 mm Phillips #2 screws near the speaker grille.
      • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
      • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
      Demander à FixBot
    2. iHome iH8BR Buttons Replacement: étape 6, image 1 de 2 iHome iH8BR Buttons Replacement: étape 6, image 2 de 2
      • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
      • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
      • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
      • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
      • Pull the back adapter cover off.
      Demander à FixBot
    3. iHome iH8BR Buttons Replacement: étape 7, image 1 de 2 iHome iH8BR Buttons Replacement: étape 7, image 2 de 2
      • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
      • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
      • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
      • One 4.0 mm Phillips #1 screw near the center of the adapter.
      • The iPod adapter should now be separate from the upper casing.
      Demander à FixBot
    4. iHome iH8BR Buttons Replacement: étape 8, image 1 de 3 iHome iH8BR Buttons Replacement: étape 8, image 2 de 3 iHome iH8BR Buttons Replacement: étape 8, image 3 de 3
      • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
      • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
      • Use tweezers to remove the 6 ribbon cables.
      Demander à FixBot
    5. iHome iH8BR Buttons Replacement: étape 9, image 1 de 1
      • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
      • You have now separated your iHome's inner workings from its protective case!
      Demander à FixBot
    1. iHome iH8BR Buttons Replacement, Buttons: étape 10, image 1 de 3 iHome iH8BR Buttons Replacement, Buttons: étape 10, image 2 de 3 iHome iH8BR Buttons Replacement, Buttons: étape 10, image 3 de 3
      • Remove the eight 7.9 mm Phillips #1 screws from the center board.
      • Use tweezers to carefully remove the largest circuit board.
      • You should be able to easily lift the buttons away.
      Demander à FixBot
3 autres ont terminé cette réparation.
cfredric
Membre depuis le 04/17/13
70 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 12-33, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
4 membres
35 tutoriels rédigés
1 commentaire de tutoriel
Suggestion here is that no parts required but if buttons broken where do I get replacements from? iHome site doesn't recognise iH8
Am in UK
thank you h
Heidi Yeo - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 24
Total : 2,813
