Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iHome iPL8 Screen Replacement
Ce dont vous avez besoin
    1. iHome iPL8 Screen Replacement, Battery: étape 1, image 1 de 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Demander à FixBot
      Ajouter un commentaire
    2. iHome iPL8 Screen Replacement: étape 2, image 1 de 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Demander à FixBot
    3. iHome iPL8 Screen Replacement: étape 3, image 1 de 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Demander à FixBot
    4. iHome iPL8 Screen Replacement: étape 4, image 1 de 2 iHome iPL8 Screen Replacement: étape 4, image 2 de 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Demander à FixBot
    1. iHome iPL8 Screen Replacement, Lightning Connector: étape 5, image 1 de 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Demander à FixBot
    2. iHome iPL8 Screen Replacement: étape 6, image 1 de 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Demander à FixBot
    3. iHome iPL8 Screen Replacement: étape 7, image 1 de 2 iHome iPL8 Screen Replacement: étape 7, image 2 de 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Demander à FixBot
    4. iHome iPL8 Screen Replacement: étape 8, image 1 de 2 iHome iPL8 Screen Replacement: étape 8, image 2 de 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Demander à FixBot
    5. iHome iPL8 Screen Replacement: étape 9, image 1 de 3 iHome iPL8 Screen Replacement: étape 9, image 2 de 3 iHome iPL8 Screen Replacement: étape 9, image 3 de 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Demander à FixBot
    1. iHome iPL8 Screen Replacement, Screen: étape 10, image 1 de 1
      • Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
      • Remove the four 2.5 mm Phillips #1 screws on the green panel.
      • Flip the green panel to reveal the front of the screen.
      Demander à FixBot
    2. iHome iPL8 Screen Replacement: étape 11, image 1 de 2 iHome iPL8 Screen Replacement: étape 11, image 2 de 2
      • Locate the transparent, rectangular plastic screen cover.
      • Gently lift the cover off.
      • The screen is now revealed. Replace the screen with a functioning one.
      Demander à FixBot
Chen Zhong
Membre depuis le 02/05/19
569 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team S18-G5, Lore Winter 2019 Membre de l'équipe UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
Hi, I have one iHome iBN20 that needs to replace the screen too.
Please guide me to open up the casing.
Thank you.
Chan - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 24
Total : 455
