Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iMac LCD Cleanup
Ce dont vous avez besoin
  1. iMac LCD Cleanup, LCD Dust removal: étape 1, image 1 de 1
    Demander à FixBot
    Ajouter un commentaire
  2. iMac LCD Cleanup: étape 2, image 1 de 1
    • Face the LCD down (be sure to have nothing between the screen and the table) ;
    • Remove 4 screws from the left bracket then 4 screws from the right bracket as displayed (the smallest is at the bottom) ;
    Demander à FixBot
  3. iMac LCD Cleanup: étape 3, image 1 de 3 iMac LCD Cleanup: étape 3, image 2 de 3 iMac LCD Cleanup: étape 3, image 3 de 3
    • Use a "Putty Knife" to separate brackets from the LCD panel frame as shown ;
    • Use a "Post-It" to keep the adhesive from the frame ;
    • Continue gently between the bracket and the frame ;
    Demander à FixBot
  4. iMac LCD Cleanup: étape 4, image 1 de 2 iMac LCD Cleanup: étape 4, image 2 de 2
    • Using the "Putty Knife" make a groove in the shield around the whole frame ;
    • Once done from the bottom center to the edges of the LCD panel unclip the frame (don't touch the top). Clips are located at :
    • Bottom left, center, right ;
    • Left bottom, top ;
    • Right bottom, top ;
    • Lift the frame 90° maximum ;
    Demander à FixBot
  5. iMac LCD Cleanup: étape 5, image 1 de 3 iMac LCD Cleanup: étape 5, image 2 de 3 iMac LCD Cleanup: étape 5, image 3 de 3
    • Using gloves and a suction cup gently lift the LCD sheet (no more than 90° failing to do so may bend the LCD and cause image displaying issues);
    • Meticulously clean the inside. Do not use any detergent at most a very lightly humidified microfiber / lint-free cloth ;
    • Do not use an air spray as those might leave marks. Best to get rid of dust is a simple hair dryer going from the top center to the edges ;
    • Reassembly is going back those steps making sure to get rid of your finger-prints ;
    Demander à FixBot
21 autres ont terminé cette réparation.
LLange
Membre depuis le 11/25/13
1 017 Réputation
1 tutoriel rédigé
24 commentaires de tutoriel
Thank you for this guide! Helped me very much. And now my iMac is clean again :)
Robert - Réponse Partager
I got the screen cleaned and all was well but when I returned everything back to the iMac the lower part of my screen didn't work...
Chris Malka - Réponse Partager
If the backligt is ok but no image check connections :
— To the logic board ;
— Then underneath the protective cover on the top of step 2 image…
If the backlight is not ok check the connector and the cable at the lower right corner of step 2 image.
Beware that if you have bended the LCD you might have damaged it.
LLange - Réponse Partager
It sounds like the LCD got bent then because the connections are fine so I just ordered a new LCD. But the guide was definitely helpful, I got the dust out!
Sorry about this I'm adding a warning on Step 5 to lift gently and no more than 90° hoping this might prevent others to have the same issue.
P.S. the LCD has an electronic board some times people have flickering issues after the display warmed-up. Thus changing that "inner-board" might solve their issue ⇒ after you receive your new LCD, try to sell the old display "inner-board" as well as the connectors…
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 118
Total : 42,858
